Old 07-05-2006, 09:22 PM
brutis07735 brutis07735 is offline
I am trying to locate the IOD fuse
can anybody tell me were the iod is located on a 93 dodge grand carvan. all guages went out, dome lights out but will work manually.something is killing battery also all fuses are good help please,I can't find a fuse box under the hood anywhere.
Old 07-06-2006, 05:16 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: I am trying to locate the IOD fuse
On a 96 it's under the hood in a fuse/relay box next to the battery. I"ve read threads in the past that in some vans it's labeled differently. Just have to find the threads.
BTW - Most say IOD stands for "ignition off draw". One stated Chrysler pulls them at the factory before shipping to keep the battery from draining then the dealer reinstalls them.
Old 07-07-2006, 02:14 AM
npye npye is offline
It's the fuse nearest the steering wheel (in the fuse box in the engine bay).
Old 07-07-2006, 10:20 AM
89ltd 89ltd is offline
disconnect the positve battery cable, using a multi meter on the dc amp setting, should be good for 10 amps, put one probe on the pos. cable and the other on the pos. battery terminal. Now you should see how amperage is being drawn. Now take out one fuse at a time and see if the reading on the multi meter drops, if it doesn't , keep trying fuses until you pull the one that makes it drop. That one will be the circuit you have the problem with. Just leave the fuse out until you have time to fix it.
