| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
To all the DSM wizards
Alrighty then 95 GSX I am sure you all should know me by now.....But the car is running fine no problems what so ever....except can someone please explain why in the world do all my lights flash when i am under throttle? checked the battery 13volts checked the alt its charging at 14.2volts can't find any loose wires or bare wires....but it bothers the hell out of me....any idea's?
Re: To all the DSM wizards
What do you mean under throttle?
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
you battery should be at 12.4v, under perfect conditions its 12.6 but never 13
2004 Flame Red SRT-4 |Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd| Mods: ![]() |
What do you mean the lights flash? Like they go on and off, or they dim?
'92 3000gt SL Zoom Stage 1 Clutch Quote:
I havent ever seen you either, nor do I have any fuckin clue what lights you are talking about. Does it only happen under WOT? The warning lights? If so, which one? Headlights? Interior lights? My guess: knock sensor setting off a CEL. What grade gas are you running? If its not 92-93 and especially if you are even slightly modded I would do a compression test and make sure its decent, then switch to 92-93 octane gas.
![]() 96 GST 5 spd.......(R.I.P.) smashed by a fallen tree 2001 Camaro SS 6 speed goodness! |
Maybe he means they dim and brighten under acceleration? Mine would do that when the bass would hit with my system. lol
-Brian
Different crank pulleys do the same. Dimmer at stop. I got a voltage stabilizer to deal with that. Lucky me.
No wonder he has so little posts, he doesn't respond.
Try getting or making a grounding kit, the grounds in your car are 11+ years old and probably don't work as well as they used to. Ebay usually has kits for less than the cost of wire you need.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff. http://www.ratemydsm.com/member/ez1286/?member=ez1286
sorry i haven't gotten back to you all i hate working 2 jobs. and yes i mean WOT. I checked everything out again and i found that the alt belt was slipping alittle bit. thanks for the info though ever come to pittsburgh i owe you all a beer.....
and yes in my younger years i did watch fight club to many times |
I win again! Woot. I doubt I will get to Pittsburgh any time soon though.
Loeman==>+1
And Loeman is on a roll! I think I'm gonna take a vacation...
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
