Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 07-05-2006, 04:38 PM
steviek's Avatar
steviek steviek is offline
Intake nipple
Does anyone know what I should hook up to this nipple on my intake?
http://i83.photobucket.com/albums/j2...Picture029.jpg
Thanks in advance
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 07-05-2006, 05:38 PM
sourcelx's Avatar
sourcelx sourcelx is offline
Re: Intake nipple
....its kinda hard to make out the pic, could you possibly get a pic from a little ways back?
Money doesent make a good technition, the love of cars do.But hey, money helps! 90GS 95GST
http://profile.myspace.com/index.cfm...endid=46463896
Old 07-05-2006, 06:32 PM
ned032002's Avatar
ned032002 ned032002 is offline
Re: Intake nipple
I believe that nipple is meant for the line that comes from the valve cover, in that case just either tape it off or plug it some how cause you don't want air going through that hole cause then the air fuel mixture might be off by a little cause then the MAF is not reading accuratly.
Old 07-05-2006, 07:55 PM
clipsekid99's Avatar
clipsekid99 clipsekid99 is offline
Send a message via AIM to clipsekid99 Send a message via MSN to clipsekid99
Re: Intake nipple
See the PM I sent you. Since you already told me it wasn't the valve cover breather nipple, or the nipple for the charcoal canister, it's the nipple that connects to the stock BCS.
2006 Wicked White Evo IX GSR
323 awhp / 311 tq. (Dynojet)
http://www.projectevoix.com
http://www.4WStuning.com
99 RS < 98 GSX < 06 EVO
Old 07-05-2006, 08:43 PM
steviek's Avatar
Re: Intake nipple
Ok well something to do with boost control is definitely a possibility because now even with my mbc on my boost runs wild again. How can I stop it should I hook my mbc to that nipple (is it a pressure source)?
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 07-05-2006, 09:24 PM
Re: Intake nipple
No, if you have an MBC, you need to cap off that nipple with a rubber stopper. That nipple has nothing to do with aftermarket boost controll. That nipple is only for the stock BCS and if you aren't using the BCS, you don't use that nipple. Are you sure you have your boost controller hooked up right?
Old 07-05-2006, 09:32 PM
steviek's Avatar
Re: Intake nipple
It was working fine up until I installed the intake. I may have knocked off the line going to the wastegate actuator I guess Ill have to check that tommorow. I can't figure out what happened.
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
