Old 07-05-2006, 05:23 PM
StewartFan20 StewartFan20 is offline
1999 f250 egr circuit code
I believe the motor is a 5.4 liter v8 and the ses light came on a little while back and when I had it read at advance the code said insufficient air flow in egr circuit. Is there something that can be removed and cleaned to correct this or maybe a hose is leaking or that needs replacing? Never seen this code on any other vehicles Ive ever driven before. Any certain part I should start looking at first and work my way down until I find the problem? The guy at advance said it probably wasnt the egr valve itself because it said "circuit". Is this a true statement?
Old 07-05-2006, 07:20 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 1999 f250 egr circuit code
Was the code P0401? If so, check the return voltage on the DPFE sensor. It should be around .6 to 1 volt with key on engine not running. Should have the same reading at idle. If voltage is out of range, replace DPFE sensor.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
