Go Back   Automotive Forums Car Chat > Toyota > Supra > Maintenance
Maintenance Have questions? Find answers. Help out fellow Supra owners.
Old 07-05-2006, 02:28 PM
fixin_dippin's Avatar
fixin_dippin fixin_dippin is offline
swapping a 2JZGTTE to my Supra??
i was thinking about buying this engine & wondering if it will be able 2 fit in my 87 supra??? Im a newb..
dont chu mess wid MY car
Old 07-05-2006, 02:56 PM
TcmaBoy's Avatar
TcmaBoy TcmaBoy is offline
AF - Advisor
Re: swapping a 2JZGTTE to my Supra??
It will, but you will need to change to a 90+ cross member, have custom engine brakets made, you can use a R154 trans with a 1JZ bell housing and flywheel if you want a stick. When you buy you will need find a front clip. Just buying an engine/ECU combo will create a lot of extra work and parts hunting. The car will need to be rewired to accept the new engine. This is not a simple drop in swap. You need to be an extremly competent mechanic and electrician to make it happen. Be prepared to spend at least $5000 on the swap.
Now, just how serious are you?
One more thing; it is a 2JZGTE. Nissan uses two Ts to indicate twin turbos. Toyota does not.
Don't you SAS me boy.
Please wheel responsibly.
http://www.treadlightly.org/
Old 07-05-2006, 05:17 PM
THANKX
