Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 07-05-2006, 01:43 PM
luvmy02impala luvmy02impala is offline
Question 90 Dakota Trans Rattle
I have a 90 Dakota, when I release the clutch, there is a rattle undearth the truck, I only notice it in Neutral. I also noticed a rattle when I upshift into the next gear - almost like the truck doesn't need to be in the next gear. Kind of like when you are in second and slow down and go aroun a corner ane the rpms are too low for the gear.
Any thoughts? Could it be the throwout bearing? Clutch? Some clunking when shifting, but not to loud, somewhat low sounding. I also hear a winding when I downshift from 3rd to 2nd.
Any suggestions? Clutch has 30k on it, tryck has 74k on it.
Thanks.
Old 07-11-2006, 07:36 PM
AwPhuch AwPhuch is offline
Banned
Re: 90 Dakota Trans Rattle
Sounds like you need to check out your transmission mount...its like a motor mount but on the transmission
Brian
AwPhuch
Old 07-17-2006, 10:53 AM
Thanks, I will check it out on Wednesday. I have to replace the reverse light switch anyway...
-TL
Old 07-19-2006, 06:29 AM
k5dan's Avatar
k5dan k5dan is offline
Send a message via Yahoo to k5dan
mine was doing the same thing, then the throw out bearing would stop releasing when it got hot, i am in the middle of replacing the clutch now.
-->1994 Ford Thunderbird LX 4.6l V8, auto trans. Completely Stock
-->1989 Dodge Dakota 3.9l v6, 5 speed manual trans, 4x4
Old 08-13-2006, 07:57 AM
joebb1955 joebb1955 is offline
throw out bearing
