Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 07-05-2006, 01:14 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Anyone having problems with their Speedo?
My speedometer stopped working as well as the odometer. I swapped clusters thinking it was just a bad cluster, that didn't work. I then checked all connections and wiring to ensure power and good contact. It turns out the VSS was bad (didn't throw a code either)! I bought a new sensor from O'Reillys Auto for $23.99, but the stock connector to the sensor would not fit the aftermarket sensor. But it does come with one that does, only you have to cut the stock wiring and splice in the wires. After that, all was good. So if you don't wanna spend the extra $20 or so and get one from the dealer, that's what you will have to do.
I also replaced the clockspring on my car, because the horn would not work, due to the broken clockspring. Anyone want a how-to on that?
Old 07-06-2006, 08:10 PM
HPNOTIQracing HPNOTIQracing is offline
Re: Anyone having problems with their Speedo?
what sensor did you replace? also did you check the speedo gear?
Old 07-07-2006, 07:44 AM
The gear was fine, it was a bad sensor.
Old 07-07-2006, 08:55 AM
i dont know where the hell my mind was at when reading that. i even missed the part about splicing the wire
Old 07-07-2006, 09:01 AM
Maybe from the HPNOTIQ you have been drinking
Old 07-07-2006, 09:06 PM
different spelling but same concept
