Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-05-2006, 04:43 AM
GSXBMX GSXBMX is offline
Send a message via AIM to GSXBMX Send a message via Yahoo to GSXBMX
eco/wiring harness?
okay so ive been looking for a new project and found a guy selling a 1991 plymouth laser rs turbo.it has exhaust,turbo timer,blow off valve,down pipe,boost controller,lowering springs and gauges.the body is almost mint and the interior ismt much worse then the body.hes only asking 1,000 dollars but he had it stored for winter and some mice ate a few wires.this is an exact qoute from his add. "this is a great project or parts car since when i put it into storage for the winter some mice ate some wires and locked up the computer not leting any spark get to the spark plugs" can this be solved by a new ecu and wiring harness?and if so..would an ecu and wiring harness from any first gen dsm like talon or eclipse work?cause im very interested in this car...so feedback is greatly appreciated.and if that is all needed to fix it...anybody know a good place to get an ecu and wiring harness?or am i going to have to start checking junkyards?
***THE TITLE WAS SUPPOSED TO SAY ECU NOT ECO...TYPO..MY BAD***
Old 07-05-2006, 10:20 AM
Re: eco/wiring harness?
anybody?help?lol...please
Old 07-05-2006, 11:19 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
I dont think the ECU would be affected if some wires got eaten through. I would open it up and look for burn marks and shit. If there is some, you should get a new one. I think it should work with just the new harness, hell if only one or two wires got chewed through, you could just reconnect, solder, and shrink tube them and be good.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 07-05-2006, 11:21 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
It sounds a little suspicious. I would ask how he knows that's for sure the problem, and how he knows. If he tells you he can see the wires that were chewed, tell him you want to see them. But...ask him in person when you go to look at the car. He might just chop up some wires and say that's the problem when there is something worse hiding.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 07-06-2006, 09:17 AM
i looked at it today.there is no burn marks on or inside the cu.the wires thar are no longer full wires were not burnt eithe.r.they do indeed looks chewed by something...think id be able to get away with soddering new wire in between them and shrink tubing them?????
Old 07-06-2006, 09:23 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
I think you could put some new pieces of wire in to fix the chewed areas. Make sure they're all connected very well you don't want some phantom electrical problems.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
