| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
Balance shaft spacer?
I'm trying to get the front case off and the only thing holding me back is this spacer that is behind where the front b-shaft sprocket was i got it off about halfway and it just won't budge. I never seen this thing on vfaq or anywhere else, I can't even find it in the haynes manual.
So anyone who has done the b-shafts before can tell me if this thing will ever some off or how they got it off I would appeciate it! Thanks 1990 TSi AWD
Tim 1990 Talon AWD 2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink, PTE SCM5031
Re: Balance shaft spacer?
That should just slide off. If the motor is on a stand, I think the shaft would just come off with the cover and you could deal with it then.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
Mine came off with the cover... Now it WON'T come off from the cover at all. lol
-Brian
Grab some pliers, move it around a little, and pull. Mine was kind of rough to get out, but it does come.
1999 Chevy Monte Carlo 3.1L 1991 Chevy Camaro 3.1L 1981 Chevy Camaro z28 383 Stroker 2000 Mercury Cougar v6 |
Unfortunately the motor is still in the car and lowering it to pull the front shaft is impossible with the way the car is sitting (halfway on a ramp). I figured it should just slide off. I'll get some vice grips and muscle on it later tonight.
Thanks for the replies...I'll be back if I need anything else.
