Go Back   Automotive Forums Car Chat > Toyota > ES300/ES330/Windom
Old 07-04-2006, 09:51 PM
DJPsystems DJPsystems is offline
Unhappy fan problem
The fan does not come on in high speed and the car runs hot. I have jumped the OP1 and E1 and it does nothing. Then I applied voltage to the solenoid valve on the PS pump and the fan works. Is there a fuse or relay that controls this? I am lost right now.
92 300ES
00 Sable DOHC duratec
86 Camaro Z28
Old 07-06-2006, 12:33 AM
Toysrme's Avatar
Toysrme Toysrme is offline
AF - Advisor
Send a message via ICQ to Toysrme Send a message via AIM to Toysrme Send a message via Yahoo to Toysrme
Cool Re: fan problem
It turns on & off by the cooling fan ECU, powered by the 15amp ECU-IG fuse.
The cooling fan ECU has it's own coolant temp sensor. Check that.
If you download the 93 FSM. That sensor is on the wiring diagrahm.pdf page 27. Marked E4 (the temp sensor by the thermostat)
I would also look at the wiring / harness.
Toysrme257th - AIM about anything, anytime; including v6 turbos.
World's second ES 300/3vz-fe Turbo.
Old 07-06-2006, 06:25 PM
Re: fan problem
The fuse is still good. I am thinking that the cooling fan ecu is fried. Where is it located? I am having problems with my computer right now and it will not download it right now.
92 300ES
86 Camaro Z28
Old 07-11-2006, 08:33 PM
Re: fan problem
Ok, I downloaded the repair manual. The fuse is good, so I think that the module is bad because it does nothing when I put a jumper between OP1 and E1. When I checked the sensor, I got about 3.45K ohms with a warmed up engine.
92 300ES
86 Camaro Z28
Old 07-25-2006, 09:00 PM
Re: fan problem
Problem solved. I changed the coolant temp sensor. I scored a cooling fan ecu on ebay, now the fan comes on like it should.
92 300ES
86 Camaro Z28
Old 06-14-2008, 05:56 PM
ArodsCustoms1 ArodsCustoms1 is offline
Re: fan problem
Hi can you tell me were to go to download the pdf file for the wiring diagram, for the fan, it is asking for a password? thanks
