Go Back   Automotive Forums Car Chat > Honda > Interior | Audio | Security
Interior | Audio | Security Tech forum to assist in Honda/Acura Interior, Audio and Security.
Old 07-04-2006, 08:18 PM
96CivicEX06's Avatar
96CivicEX06 96CivicEX06 is offline
Send a message via MSN to 96CivicEX06
I've got a problem...
OK I'm fiberglassing kickpanels for my '96 Civic thus I have to move my ECU somewhere else, what I did was lengthen the wires because I thought I could move it in the glovebox... didn't work, so I uncrimped them and soldered them to the original and now the CD player doesn't work ... everything else seems to be working fine. Is there a pin for the CD-on in the ECU or do you think I might've blown a fuse from doing this project? any help would be greatly appreciated.
Silly ricer, wings are for planes
Old 07-05-2006, 09:13 PM
InstallTech's Avatar
InstallTech InstallTech is offline
Re: I've got a problem...
I'd check your fuses first. Highly unlikely that the radio operates through the ECU.
I reject your reality, and substitute it with my own.
Old 07-05-2006, 10:06 PM
Yeah you're right Install... the backup fuse (7.5A) that operates the memory was blown. I also went on a honda-tech forum and they said there is no radio operator in the ECU, so you're right on.
Old 07-05-2006, 11:02 PM
Glad it was an easy fix. Good luck with those kick panels.
Old 07-06-2006, 11:36 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Originally Posted by 96CivicEX06
...what I did was lengthen the wires because I thought I could move it in the glovebox... didn't work, so I uncrimped them and soldered them to the original...
What you did was officially molest your harness. I hope it doesn't throw any sensors off.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
