96 Jetta A/C problems
Hello everybody!
I have a 96 Jetta with 2.0 L engine and manual transmission.I had my A/C system checked in a shop and it seems like there is an electrical problem.When I start the car,the system is cooling for few minutes very well and then dies.Anyone can help me with this matter? Thanks. |
Re: 96 Jetta A/C problems
I'm also having probs with my AC in our 1994 Jetta. I believe that mine is due to a bad compressor, however. Does anyone know how expensive this repair is? Also, could I replace the compressor myself? Does anyone have a how-to for this job as a DIY? Or am I just crazy................?
For the first part of the thread, check your relays and fuses. I don't have a manual for your year, so I'm afraid your on your own.
Second thread: 1. Take your car to a shop and have the A/C system evacuated. Do NOT discharge the freon into the atmosphere! 2. Get a new compressor on line. I tried to get a price, but they seem to be unavailable at the places I ususally connect to. Expect $125 to $175 3. Get a new reciever drier (removes moisture). This must be replaced if the system is opened up. 4. Take apart all the hose fittings and collect the o-rings. Get replacements for all the o-rings. It will cost about 5.00, but will save you in the long run. Flushing the hoses with appropriate solvent isn't a bad idea. 5. Put in new o-rings, install compressor and new drier, and place a vacuum source on the system. All air and moisture should be removed. 6. Charge with oil if compressor doesn't already have appropriate amount of oil in it. Turn on the A/C full blast with engine running and charge the freon. |
