Old 07-04-2006, 01:25 PM
Dyno247365's Avatar
Dyno247365 Dyno247365 is offline
stretched chain, is it that bad?
A DOHC japanese engine with an upper and lower timing chain. The upper lost it's slack and it hits the valve cover. I've had this car for 3 years and it never caused any problems. I decided to go gung-ho and jump into replacing the timing chains and tensioners and when I took the valve cover off, everything looks fine. Does it really need to be replaced when everything's working? Is hitting the valve cover that bad?
1996 Dodge Ram 1500 5.2L 5spd!!!
1987 Chevy Iroc-Z- -Needs a new cat
1992 Nissan 240sx 5spd- SOLD
Old 07-04-2006, 01:34 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: stretched chain, is it that bad?
If its stretched its throwing off the timing some. It should be fairly simple to replace.
Old 07-04-2006, 02:06 PM
Dyno247365's Avatar
Someone's telling me it's the timing chain guide's fault, there's the one on top and the passenger's side of the chain is scratching the valve cover a bit. Just that side.
Old 07-04-2006, 03:09 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
If its a high millage Nissan (which I assume it is) then just replace the chains and tensioners.
Far safer than having a chain break, skip a tooth, and stretch even further.
Old 07-04-2006, 03:17 PM
Dyno247365's Avatar
99k
Old 07-04-2006, 06:06 PM
Carbon Fibre's Avatar
Carbon Fibre Carbon Fibre is offline
you are supposed to change it at 65k. Unless you like bent valves and broken parts, CHANGE IT.
The Builder
Old 07-04-2006, 07:58 PM
Dyno247365's Avatar
You change your timing chains at 65,000?
Old 07-04-2006, 08:32 PM
Moppie's Avatar
Master Connector
Timing chains have a much longer life than 65,000 miles (100,000km) which is the norm for a belt.
I know Nissan do recomend a change period, but I forget what it is.
However, I believe its around twice that of a belt, so at 100,000 miles its possible the chain has stretched.
Old 07-04-2006, 10:07 PM
Forunn Daberator
If I remember correctly those engines have a timing chain that is very long, and had a shorter "life span" than most chains due to the extra length.
Old 07-06-2006, 02:24 PM
Oh yea. i was thinking if a belt. But it seems like it's obviously stretched, though.
The Builder
Old 07-06-2006, 05:36 PM
UncleBob UncleBob is offline
AF -Advisor
I've seen nissan chains wear all the way through the timing cover, dump all the oil out, and seize the motor.
And then, it could always break too.
Not something I would just ignore, but I assume you're talking about a 2.4L, they aren't the funnest chains to do. Been a while since I've done one, but I think they call out for 12 hours of labor or so
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 07-13-2006, 09:15 PM
kevinthenerd kevinthenerd is offline
If it was me, I'd replace it. If it breaks, there's a good chance it will total your motor. Isn't a weekend worth at least that?
