Old 07-04-2006, 01:22 PM
3.1L 200+hp's Avatar
3.1L 200+hp 3.1L 200+hp is offline
voltage ?
ok i just put an alternator on my firebird after finding out that it was dead i drove it for a week with that bad alternator i put the new one on and whenever i stop at a red light for about 10 sec. or longer my voltage drops down and car dies but it will fireright back up i was wondering if u thought it was the batter but i did take it to advance and it tested good which confused me. i had the car running disconntected the batter to see if a ihad a faulty alternator but my car stayed running so the alternator was good. any1 have any suggestions any help would be nice thanx
Zack
Old 07-05-2006, 10:44 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: voltage ?
Did you charge the battery before starting it up after replacing the alternator?
Sure the belt tension is good?
Old 07-05-2006, 01:17 PM
Re: voltage ?
ok the batter was charged up and i have came to the conclusion that its not the battery b/c i took batter from other firebird and its doing the same thing and yesterday it idled in park for 10 min. no problem when i put it in gear the car died. Torque converter will cause it to die when shifting in gear but will it cause it to die if it has been in gear and ur just sitting there?
Zack
Old 07-05-2006, 04:55 PM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
Re: voltage ?
when its just 'idling' is it idling good?
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 07-06-2006, 03:53 PM
Re: voltage ?
when it idles it is fine but once u shift it into gear it sureges and sometimes dies
Old 07-06-2006, 04:21 PM
Re: voltage ?
is it just me or does it sound more like a vaccum line problem? you have a auto, right?
Car:
285's in the back
all else = STOCK.
Old 07-06-2006, 04:22 PM
Re: voltage ?
i highly dopubt the torque convertor can stall out your engine..ive heard of it not engaging..but not of it engaging too much..
Car:
285's in the back
all else = STOCK.
Old 07-07-2006, 10:20 AM
wrightz28's Avatar
Re: voltage ?
If the TCC (torque converter clutch) goes south, it can stall the motor, it'd be almost the sameas dropping the clutch without throttle on a stick.
Old 07-10-2006, 01:51 AM
Re: voltage ?
ok thanx i will check into the TCC and yes my car is an automatic
Old 07-10-2006, 02:38 AM
Re: voltage ?
really? damn, ive had crazy amounts of crappy automagic cars and ive never had the tcc fry on me.. haha
when it idles like crap, does it jump around like the engine is straining to move? or does it just sort of crap out like the engine is being starved of something..
Car:
285's in the back
all else = STOCK.
Old 07-10-2006, 03:15 PM
Re: voltage ?
The motor will bog down shift hard and then kill over
