Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 07-04-2006, 12:00 PM
kinseyz28 kinseyz28 is offline
no ac compressor or power steering
i just bought a 95 neon dodge. i cannot believe this car didnt come with a ac compressor or a power steering pump. now my question is what type of modification i need to do to install ac in this car. do i just buy a compressor an install that. i can live with the power steering. but what do i nned to do with the power steering pump. please any advice.
Old 07-04-2006, 11:41 PM
Wollf's Avatar
Wollf Wollf is offline
Re: no ac compressor or power steering
can you take a picture of the belt system ? its VERY rare to have no power steering , ac i can see... but PS ? wierd.
I work as a partsman in the BC Area if you need help finding something you cant find pm me here and i will see what i can do. www.lordco.com
Better to sit in silence and be thought stupid , then to open your mouth and remove all doubt.
Old 07-05-2006, 01:51 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Maybe the previous owner took off the P/S stuff to free up HP and free up space in the engine bay. Besides some neons did come without P/S.
To the original poster, you can go to a junkyard and pull off all the A/C and P/S parts and put them on your car. However, if you choose to just install A/C you will run into a slight problem. The A/C and P/S belts all rotate off the crank pulley and the P/S pump is what provides the tension. You can measure the distance around the crank pulley and A/C and go look for a belt that would fit. You would have to then force the belt on as much as you can, then bump the starter to get it all the way on.
Old 07-06-2006, 05:17 AM
FemaleRacer FemaleRacer is offline
Just FYI-that is NOT AN EASY thing to do. Of course it's very possible-but unless you have a really good mechanical ability and a lot of practice under the hood you may want to take it to a shop. Please son't be offened!!! If you are a regular mechanic-that's great. I just know that when I replaced my old engine and had to re-adjust it with the old pullys and belts-it was hard enough. You have to be right on or you'll eat through your belt. Which is not only an obnoxious squell-but bad for the car when it finally gives Just something to think about when considering the addition to your car. the best of luck to you!!!
Don't let the 34JJ's and 6" heels throw you off...I race to win. No games. Just you in my rearview mirror
Old 07-06-2006, 09:02 AM
What's to line-up? His crank pulley is on the car already and that is the one that is usually off alignment. The P/S pulley has a bracket that it goes on to help line-up and so does the A/C. It isn't that difficult at all.
Old 07-06-2006, 09:19 PM
HPNOTIQracing HPNOTIQracing is offline
very easy job imo. ther are places to bolt it right to. if you want a little knowledge about it buy a haynes manual from autozone
you have to know how something works(belt system) before you can properly fix it!
