Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 07-03-2006, 11:32 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Running a water cooled turbo without the water cooled part. Bad?
So my buddy was telling me how when he ran his 14b on his Civic, he didnt plumb in coolant lines for it and it worked just fine. Is this ok?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 07-04-2006, 01:19 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Running a water cooled turbo without the water cooled part. Bad?
Many people do this. It's better to have a center section that is meant to be "dry," but people have run 14bs and 16gs dry with good success. Not sure I would do it on a daily driver that sees 100 degree heat in stop and go traffic every day, but... you get the idea. Try it at your own risk.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-04-2006, 09:56 AM
Thor06's Avatar
Jizzed In My Pants
Oh, I wasnt going to do it on mine. Just a random question I thought of. The way I see it is they put the "water cooled" part there for a reason .
Old 07-04-2006, 08:26 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Yeah some people do it and notice no difference, but I have seen a couple cases where they blew their turbo significantly early. I guess it's like gambling.
now - 2000 civic
soon - 2002 is300
Old 07-06-2006, 05:49 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
i ran my 14b like that after my motor rebuild and it was fine. then i switched over to a used 16g that had been run dry for awhile before and its still dry and fine on mine.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
