| General Discuss anything having to do with Toyota Supra here. |
Ok i had boughyt a 1990 supra last Febuary knowing it had a bad motor well i made it 20 miles from where i bought it i towed it home and ordered a JDM motor from canada well i spent 6 months puting the damn thing in and a whole bunch of new stuff i finish and prim evry thing and it dose not start and when i hook up the battery it wont shut of and my baby wont start i wnat to get rid of the stock alarm if thats the case i ve tryed to find it cant and when it dose work the start will click and the gages go all funky pleaz help if u can .
Re: Supra disaster
Ok, I am having a hard time understanding here. It helps if you use punctuation and capitalization to separate your ideas into sentences.
From what I can gather you bought a Supra with a blown motor. Then you ordered a replacement motor. You installed it. Now you cannot get it started. Is this correct? I need to know what motor you started with, the motor you swapped in, what you have replaced on it, and you need to be very clear as to the problems you are having. |
Re: Supra disaster
It sounds like you have some serious electrical issues. It may not be the alarm. If it was the gauges would not go crazy. Somthing is shorting out to the body. You should take a look at the alarm syetem as well. There is a good chance it is not stock. You need to find some wire diagrams and a mulitmeter and get to work.
http://www.cygnusx1.net/supra/library/TSRM/index.html |
Re: Supra disaster
It's easy to hot wire the starter. Just run a jumper from the battery to the little wire on the starter. I can't say anything for your alarm.
Re: Supra disaster
i have tested it it works but when i connect it to the engine it wont kik the engine over
Re: Supra disaster
How did you test it? Did you completly remove the starter, or just hotwire it?
Re: Supra disaster
Re: Supra disaster
The clicking noise is the starter relay.
You really need to be specific in what you post. I am having a hard time understanding you. |
Re: Supra disaster
ok again sorry for that i took out the starter and tested and checked the wiers going to the starter they had six volts now nothing and i need to know if there is suposed to be a ground on the starter seperate from the the battery i then hooked up the main positive cable to the stater and now no power
Re: Supra disaster
That 6 volts thing is bugging me. Have you checked battery voltage yet? Have you checked resistance on the main battery cable? If the starter is only getting 6 volts that is a problem.
Re: Supra disaster
yes and the volts on the batteryis 12 how do i check the resistance on the main battery cable |
Re: Supra disaster
If the battery is good then you may have a rotten cable. You can check resistance with the multimeter on the ohm setting, it usually has an omega symbol on the setting. It should read 0 to 0.5. If it is higher, or reads OL then the wire is bad.
Re: Supra disaster
ok i did what u said i now have 12 volts in all my wiers but the starter still will not work ive tested both and both ruin i hot wire them.
