Old 07-03-2006, 05:55 PM
OldsBuickGuy82 OldsBuickGuy82 is offline
1993 Bucking Up Hill
1993 LeSabre sometimes does a jumping/bucking thing when heading up hill. It doesn't always happen. Any idea what might cause this?..167,000 KM (not sure what that is in miles) on engin and transmission.
Thanks
Old 07-03-2006, 06:56 PM
maxwedge maxwedge is online now
A990 racer
Re: 1993 Bucking Up Hill
Thanks
Lots of possibilities here, bad plug, wire, coil, too lean a mixture, torque convertor clutch slipping, got to do addt'l diagnostics. Miles is .62 x KM's.
Old 07-03-2006, 07:28 PM
imidazol97 imidazol97 is offline
AF -Advisor
Mine did that at about 90K miles with bad plug wires and needing new plugs. AND if I recall correctly I had the dealer put in an updated ROM in the computer that adjusted the torque converter lockup speed to a higher speed. Because it's a solid connection through the locked up torque converter, you feel the least roughness in the motor just like on a manual transmission car. I believe the new chip also adjusted the mixture some but I don't know that for sure. It did increase the minimum lockup speed.
I'd get original equipment quality wires on that car if it's had replacements that were the superdooper blue or red type wires from the local box store. I'd put original AC plugs in it--whatever they recommend on the books now at Advance or PepBoys. Then see what you've got.
IIRC I thought I probably had an EGR valve acting up. But that wasn't it at all.
Old 07-07-2006, 12:53 AM
Thanks!
