Old 07-03-2006, 05:59 PM
bboyz_dogg bboyz_dogg is offline
problem with radiator????
Well i have a problem with my 91 honda civic hatch back. everytime i run it to around 50 to 60 miles the temperature gauge starts to rise. And one time it went all the way up to the H in the freeway so i got off and started taking small streets. once i got home i checked to see if it had water or anything and it was all full. so i checked everything else like the oil. and everything seems fine. but once i was driving i kind of noticed that the radiator fan didnt turn on. i think thats the problem. unless the fan is so quiet that i cant hear it? well what does everybody think?
Old 07-03-2006, 06:14 PM
h22hatch91 h22hatch91 is offline
Re: problem with radiator????
check the fan...if thats not it i would say the thermostat.....
Old 07-03-2006, 06:17 PM
well im saying its the fan because i never actually seen the fan on at all. is there a way to fix that or to see if it actually works?
Old 07-03-2006, 06:49 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
let the car warm up for a few minutes and the fan should kick on.
Old 07-03-2006, 10:05 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
After lettting the car warm up feel both radiator hoses. If the top one is hot and the bottom one is ice cold, your thermostat is definitely sticking. Get that replaced. Also make sure you are not leaking any coolant, double check the radiator and all your hoses and also around the water pump area. Good luck.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 07-04-2006, 11:36 AM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
IMO I think you should check the radiator too, it might be blocked internally or some of the fins have rotted away decreasing the radiator's ability to disipate heat. Because at those speeds and above there should be plenty of air to keep the temps under control.
You can check the fans manually, the plug for the radiator fan is under the battery. Just use test wires to hook it up to 12v. The temp sensor for the fan is located on the back of the block below the intake manifold.
The fan relay is on the passenger side near the headlight. To check the fan relay (it should be clip side up) there should be continuity between the upper left (a) and lower left (b) connections when 12v is applied to the upper right (c) and lower right (d) connections. GL
Code:
 Fan Relay
      ____---____
     |  a__ c__    |
     |  b__ d__    |
      __________
