| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
Pinched lower radiator hose
I posted a thread about my car overheating and I was checking out all of the hoses. I noticed my lower radiator hose is pinched shut. When I try to pull it apart it just sucks back closed. It is not completely closed but, it is deffinatly restricted. Any ideas as to what is causing it?
95 GSX 5 speed 2.3L stroker bored .020 over Built head Bullseye/Borg Warner T04B 57 Trim Turbo RNR 3" turboback w/ o2 eliminator 255 lph Extreme Motorsports fuel pump Extreme Motorsports mbc SAFC Greddy Type S BOV FMIC (core 28x10.5x3.5) FIC 650cc fuel injectors RK Sport Fuel Pressure Regulator My Car Domain |
Re: Pinched lower radiator hose
it's old?
just replace it, that pipe sucks though because you have to drain everything.
now - 2000 civic soon - 2002 is300
The pipe might be too long or it could be turned the wrong way causing the kink in it.
-Brian
Odds are you need a new radiator cap.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
Your hose has been heated pinched so now it will stay like that, you need to get a new one now
Current Cars 2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod. 2003 Grand AM GT - official beater car for the winter lol ---------------------------------------------------- 95 TSI AWD [email protected] (T-25) Now fully Modded engine with 3,560 miles on it.SOLD |
Yeah I planned on getting a new one and I called advanced auto parts but, the tell me they do not have it and can not get it. They tell me to go to the dealership.
Bullshit because i just got one for my 1g head swap, goto napa thats where i got mine there for $14
Current Cars 2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod. 2003 Grand AM GT - official beater car for the winter lol ---------------------------------------------------- 95 TSI AWD [email protected] (T-25) Now fully Modded engine with 3,560 miles on it.SOLD Last edited by Talon69; 07-04-2006 at 09:28 AM. |
Awesome, there is one right in town here. I hope they are open on July 4th.
radiator caps have a 2 way valve in them and if they stick closed they wont vent off the pressure and they cause a whole bunch of problems. Lower hoses getting sucked flat are usually caused by blockage somewhere, but try replacing the hose and cap first and if it still happens look to clean out your radiator
2004 Flame Red SRT-4 |Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd| Mods: ![]() |
Hmm. I will try to do this all tommarow(I have off work). Hopefully the stores will be open tommarow or at least part of tommarow. How exactly would I go about cleaning my radiator out? If it is going to be too much of a pain in the ass I'm thinking about just buying a new radiator along with fans.
Well if it keeps getting sucked flat that is your best bet
Thanks guys. I'll do all of this tommarow along with take care of some body cancer I've been wanting to kill.
When the coolant heats up it expands, and some of it moves into the recovery/overflow tank (hence the different level markings for cold and hot). When the coolant cools back down it contracts, and should pull coolant back into the radiator from the recovery tank (this is why the system has to be closed, and there is a siphon tube that extends to the bottom of the recovery tank). If the radiator cap doesn't allow the coolant to be pulled back in the negative pressure in the system will collapse the hose. Naturally, I'm assuming you noticed this condition with the car off. If it stays the same with teh car running, or it does not snap back when you remove the radiator cap, it could be a restriction as mentioned above.
This happened on the EVO once. A bad HG put a quart or two of oil in the cooling system. The oil caused all of the rubber seals in the system to swell up and expand. The rubber gasket under the radiator cap was so big that when I put the cap on it would block the passage to the overflow tank, and when the car cooled the radiator hoses would collapse.
Radiator cap is cheap! Replace once a year, WTF, over and out? It is money well spent. The cap is the least looked at part of the cooling system IMHO. Even though it can cause probs. just as quick as any other part of the cooling system.
![]() 96 GST 5 spd.......(R.I.P.) smashed by a fallen tree 2001 Camaro SS 6 speed goodness! |
