Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-03-2006, 11:28 AM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
420a Smoking
Man o man... I have trhe 420a... Eclipse RS (97)... and it has developed the problem of a faulty IAT... I assumed this was why, but I have second thoughts...
On startup... the car runs fine... but after running for awhile... the car begins to smoke, really bad... a light-black smoke (I think)... and you can smell straight gas... (the car is running really rich)... I had on my AC the other night, and I was pulling up to a stop sign... I pushed in the clutch and watched the tachometer, as it bounced from zero to 700 rpms... it only bounced that low once, stuttered then went back to 700-800 rpms... I hit the accelerator, hit 4k rpms, and dropped it... the same thing happened... the car is running really rich while sitting... and I'm not sure if it leans out at the top or what, but it's not nearly as fast/responsive as it used to be...
the car idles ok when the A/C is off, but still smokes...
I have noticed that sometimes, if I hold higher RPMs and push in the clutch (to stop) the car takes a long time to drop back to it's idle RPMs, it likes to drop really fast to 2k RPM and then takes awhile to drop back to idle...
Any ideas ,or help...
anyone know of somewhere I can buy the IAT, anybody have PN???
Thanks in advance,
-Mikelb
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 07-03-2006, 11:39 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: 420a Smoking
Mine does this sometime too. My EGR valve is bad. So I know that's causing the problem for me. It just sits at 2k sometimes when rolling up, and doesn't drop until you're about to stop.
My rpms would suck at idle when my TPS and/or the IAC was bad.
For the richness you may have a leak, either head or FIs.
I personally say it's time to take it to a shop that has a good computer and get all the senors checked out. You're gas mileage has to suck ass.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 07-03-2006, 11:43 AM
Mikelb's Avatar
Re: 420a Smoking
Had it scanned... the IAT is gone... I even checked it... so I know that's a problem... and that tells the car how much gas to give based on outside temp... right?
Gas mileage isn't too bad... less it's s'posed to get more than 27MPG
