Go Back   Automotive Forums Car Chat > Cadillac > DTS
Old 07-03-2006, 02:22 AM
1987ss's Avatar
1987ss 1987ss is offline
hard up shift into 2nd
my buddie has a dts with the 4T80E tranny im unsure or year it has heads up night vision 2000 -03? but when tranny shifts in to 2nd gear its a really hard up shift its a hard grab... tranny does not slip and shifts fine into and out of any gear but 2nd.. anybody had same problem or know if it can be a vaccume related problem??
Old 07-03-2006, 07:09 AM
DFBonnett DFBonnett is offline
Re: hard up shift into 2nd
How many miles? Has the tranny fluid ever been changed? Sometimes those problems are caused by sticking or failing shift solenoids and the fluid change solves the problem. As a last shot before dropping the valve body you might try some Lucas TransFix. I'm not much of a believer in additives to alleviate a mechanical problem, but they do have their place.
FWIW
YMMV
Old 07-03-2006, 11:40 AM
1987ss's Avatar
the car has 77 k on it.. it has been flushed and it didnt change a thing.. thanks for the reply!!
Old 07-03-2006, 02:32 PM
maxwedge maxwedge is offline
A990 racer
Lightbulb Re: hard up shift into 2nd
This should be scanned ( only a trans capable scanner will work) for possible problems with the shift solenoid or the pcs solenoid, as Df bonnet says, the adaptive shift percentages can point to the problem
Old 07-03-2006, 05:37 PM
1987ss's Avatar
kennedy transmission flushed it and scanned it thy said it didnt pull back any codes.. that tranny is expensive too he doesnt want to change it..
Old 07-03-2006, 06:59 PM
A990 racer
It is not a matter of codes, it is a matter of analyzing live data from the trans info.
Old 07-05-2006, 08:20 PM
1987ss's Avatar
what could u add to smooth it out a little so it can be traded in?
