few questions
1 my car has this thing hanging in the back on ther driver side behimd the tire does amyome no what it is my car is making a woo sound like am owl is it form that thing hanging
2 a rear min oil seal does anyone no how much that will cost to fix 3 if a camaro is a v8 would it say z28 or did they make camoro with a v8 that does not say z28 if so whats the diff 4 95 firebird 3.4 vs 88 firebird 2.8 stick thanks |
Re: few questions
2) Not sure, I would recommend calling some shops around your area. Prices often vary from locations and buisnesses. 3) The V8 Camaro's were labeled as a Z28, or an SS. If it has no badge but yet is a V8, then either the owner debadged the car, or the owner did an engine swap from a V6 to a V8 (which you rarely ever see) 4) The 3.4 would win. Reasons: The 2.8: 135hp W/ 180tq The 3.4: 160hp w/ 200tq The driver with the automatic 3.4 may not have as good of a launch as the driver with the stick 2.8, but that depends on how skille dthe driver with the 3.4 is with launching an automatic. But regardless, with the 3.4 creating 25 more horses 20 more ft/lbs of torque, and both the cars almost the same weight I see the 3.4 winning. If you research the 3.4L some, you will learn that the 3.4 is a decendant of the 2.8. GM came out with the 2.8L originally in the earlier 3rd gens. Then in 1990 they released the 3.1L, which is a bored and stroked 2.8L with the same design. Then in 1993 GM came out with the 3.4L, which is a bored out version of the 3.1L (same stroke though) with a new upper intake manifold design. So as you can see, all 3 engines are identical, just over time have seen changes in designs and increased displacement.
- Jason 1995 Pontiac Firebird ![]() ![]() User Guidelines | VB Codes Explained | AF Merchandise "Each of us, is in the scheme of things, insignificant. But millions of insignificant people, doing a tiny bit, can add up to be a very significant force." |
Re: few questions
it not a mudflap lolits round and has a cord on it some one said they think it has to do with the gas tanks and what the heck is a differential
Re: few questions
As for the differential, http://auto.howstuffworks.com/differ....htm/printable Read that, explains everything.
Re: few questions
the only thing that would hang from your car should be either static stips or curb feelers.
Static strips use static electricity from the ground, via a cloth strip, to keep a spark from happeneing as you fill up your gas tank after getting in and out of your vehicle. And a curb feeler is someting that sticks out past your tire so that when you come close to a curb they make a loud noise, but you usually only see these on older cars or cars with huge rims, or rims that have a center that sticks out farther than the rest of the tire.
![]() 1993 Honda Civic Si D16z6 Production Sequence #531567 Made In Alliston, Canada |
Re: few questions
i will try to get a pic up but if it the differential how do u fix it
here are the pic
Re: here are the pic
I would need a pic not so close up.
1999 Pontiac Trans Am WS.6 #1747 Stock'ish' |
I merged this thread you just started with the other one you already had created on the topic. You don't need to start a new thread when you already have an active thread open on the same topic. As for your pics, I'm with Mr. Luos, I would need to see a picture that's not so close up, give it a couple of feet away and that would help.
Re: few questions
Re: few questions
Sure looks like a EVAP canister to me.
Re: few questions
what the heck is that
Re: few questions
Evaporative emissions control system. Since these are sealed system vehicles in repsects to the fuel system, gasoline vaprs are removed via a charged charcoal filtering system which s/b that canister.
Re: few questions
I was beginning to wonder why you had an EVAP system, I've never seen anyone have that on an F-body.. But now I see you're located in Cali, so it makes sense that you have it on yours since you have to go through some strict emissions testing. Hopefully you'll have no problems with passing the tests even with that thing off.
Re: few questions
EVAPS have been on GM's in one fashion or another for quite some time, regardless of location. I just know on 4th gen f-bodies they moved the canister to the rear of car instead of in the left front fender.
