Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-02-2006, 07:21 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
Over heating problem
Okay so, about a week ago my car was overheating because, of a bad thermostat. So, I replaced the thermostat and put all new coolant into my car. The other night I got on the interstate and my temp gauge started to slowly creep towards hot. So, I took it out of gear and it dropped almost as fast as the RPMs. I ended up turning around and going home. I noticed the temp went up only on the highway. The temp did not rise when idleing or city driving. When the temp gauge would go down when it was "hot" when ever I would let off the gas or take it out of gear. I checked my coolant and it was fine. I also took my radiator cap off and squeezed the rubber tubing a bit to see if there was much air. Today I took it on the highway and went down just one exit. My car didn't overheat. It also has not overheated in hard city driving. Obviously there is no way my car can overheat in like 5 seconds and then cool down in just a few seconds. Any ideas as to what this could be?
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 07-02-2006, 07:45 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: Over heating problem
Temperature sensor get fried?
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 07-02-2006, 07:48 PM
Killa's Avatar
Killa Killa is offline
that might be a problem, check that temperture connection. BTW if I saw my car over heat, I stop my car right away pop the hood, not turn around driving home like you .
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 07-02-2006, 07:56 PM
NateS's Avatar
No see my car would cool down to normal temp when ever I let off the gas. Trust me I didn't drive my car home all the way with the temp reading HOT. It only started to overheat when I would give it gas. As soon as I would let off the gas it would drop to normal temp.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 07-04-2006, 12:15 AM
NateS's Avatar
Okay, so a friend says it is my head gasket. He says it probably has a very small leak and the coolant is getting sucked into the pistons after getting pressurized. He told me I should remove my thermostat untill I can get the head gasket replaced. Any one have some input on this?
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
