Go Back   Automotive Forums Car Chat > Ford > Econoline
Old 07-02-2006, 06:51 PM
billthcat billthcat is offline
92 E350 turn signal problem
The flashers work fine, but nothing happens when I turn the turn signal lever on. No lights come on. I located the the flasher switch box or solinoid?, but cant find the one for the turn signals. The wipers work, so I dont think it is the lever that is the problem.
Any help??
Old 07-03-2006, 01:43 AM
KimMG KimMG is offline
AF - Advisor
Re: 92 E350 turn signal problem
Have you checked all the fuses to make sure the circuits have power? Try bypassing the switch. It is possible that the turn signal part of the switch is bad, so you need to use a test light or meter to test it.
