Old 07-02-2006, 05:19 PM
M330CSi M330CSi is offline
Dexcool or non Dexcool?
97 3.1 GA SE
I'm getting ready to flush my coolant, and wondering what to replace it with. Pontiac obviously recommends Dexcool, but I've gotten vibes from people (mechanics and such) that it's not the best choice. Is there something about dexcool that I should be aware of? What are it's advantages/disadvantages? What else can I use in my coolant system?
Thanks!
Old 07-02-2006, 10:53 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Dexcool or non Dexcool?
Thiers nothing wrong with green antifreeze.
They recomend it for two reasons.
One it gives a 10deg plus/minus advantage. mainly due to sodium glyco.
Two it is supposed to hav a less chemical reaction between the may metals within the engine. steel block, aluminum heads/intake, brass recirculator tubes
I personally dont like dex because it gets a brownish foam build up in the resivour. Makes it hard to tell if oil contamination is in the dex, because it always looks nasty.
Cost more most of the time too.
They do sell an aditive, I think its called "WET", which you add to the coolant(not sure if it works in both) and it is suposed to giv you cooler runing temps.
Havnt tried it yet myself, but I'm sure I will just to see how and if it works.
1999 Grand Am SS 3.4 OHV
Old 07-03-2006, 06:23 PM
skibum1111 skibum1111 is offline
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
I think what you are thinking about is called water wetter, supposed to make your car run cooler by 10 degrees or so. From what I've heard, the stuff works very well with the green stuff, none of my friends run the pink crap so I have not heard anything about if it works with it or not.
Rusting out Honda Civic $900
Fart cannon muffler: $300
Assorted stickers advertising products you'll never own: $50
Having your @ss handed to you by a brick shaped suv: Priceless.
Yup, I own the suv.
Old 07-03-2006, 09:20 PM
gravis2000 gravis2000 is offline
Here is the deal the product you are referring to is called water wetter and it breaks the surface tenson in the water to allow it to absorb more heat. Now the water wetter is liquid soap like Dawn or Joy. I put about 12 oz in my car and it did lower the temp about 15 degrees.
