Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 07-02-2006, 01:28 PM
silvrcvik silvrcvik is offline
odd rpm gauge question
im such a noob, and ive tried searching threads but i cant find sh*te.
hopped in my car went for a drive today...drives fine..
but when i hit 4000-4200 rpm the gauges stops...
as did the mph gauge too, at first.
Car sounds fine, its just the gauges, once i shift down or up,
the gauge drops back down quickly but normally.
a year ago i had a crankshaft crap out on me, dealer swapped in a new motor, but did say that the vtec wasnt working....could the vtec not be kicking in or something??? im slowly workin on gettin more edjumacated. but im no mechanic. thanks
Old 07-02-2006, 09:06 PM
bluevp00's Avatar
bluevp00 bluevp00 is offline
Re: odd rpm gauge question
It does seem to be something related to VTEC that's your problem. VTEC activates at around 4200 RPM, right where your tach stops working. But from there I don't really know, maybe check the crank sensor?
Old 07-02-2006, 10:55 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
I don't think the problem is related to vtec because 1) vtec engagues around 4800-5000 and 2) while vtec depends on rpm input, it does not depend on the tachometer. So if vtec and the tachometer are both not functioning, it's the rpm signal. Check the wires from the cam position senor and crank angle sensor.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
