I recently did all the wiring on my 2007 yukon for a sound system. I got everything working properly my 12 volt source my ground and everything but I have one little major problem. I can't seem to find where to connect the rem wire i've tried connecting it to all the fuses on the inside fuse box and some of them give it power without turning it off and some give it no power.What can i do? I'm running the stock head unit. Need help please Thanks.
Re: REM wire problem
Find a fuse thats only hot in the run position of the ignition. A test light helps, too.
2007 Certified DaimlerChrysler Service Technician... True blue GM at heart. |
What do you mean I don't really understand what you are saying. I tried doing the fuses that were on only durin the run but when i turned off the key the fusese would still stay on all of them i tried all of em. Where can i get one of those test light thingies?
Any auto parts store or wal-mart. There has to be a fuse thats only hot in "run", it's just finding it......
Im kinda new 2 this so 2 find that hot fuse i have 2 see that it goes off when the ignition on the truck is off and that is on when the ignition goes on.Im like 95% sure that i tried every fuse like that and most of them stayed on except one but that one caused my system 2 get very high static and its not static from the power wires with the rca because im running them on opposite sides. So whats that thing called exactly to test the fuses?
