Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-01-2006, 11:30 PM
superjtrdr superjtrdr is offline
Hard to start if its cold only
I have a 99 Mustang 3.8 liter manual,transmission 92,000 miles
If I haven't started it in 4 hours or more I have to crank it about 4-5 times to get it started. Once its started it runs perfect and it startes back up just fine so long as it's has only been parked for a few hours. At first this would just happen every once and a while but no every moring I have to crank 4-5 times.
A friend told me it had to be the electronic choke scensor. this part cost me around $19 and it didn't fix the problem.
Anybody out there have any theories?
thanks you
Old 07-04-2006, 05:41 PM
neatofrito1618 neatofrito1618 is offline
Send a message via AIM to neatofrito1618 Send a message via Yahoo to neatofrito1618
Re: Hard to start if its cold only
Sounds like the fuel pump to me.
Edit- The weather wouldent really have a effect on that, but its the best I can come up with.
Old 07-04-2006, 07:28 PM
I sorry I didn't clarify that
It's not when cold just when I haven't started it in a while. I guess I associated that with cold.I am in south texas. Thier is no cold
thanks for the reply
I am told that a fuel pump means major surgery
Old 07-04-2006, 08:54 PM
Oh, that makes sence. Its probaly the fuel pump then.
Old 07-04-2006, 10:11 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
thanks you
Could be a few different things, Such as bad fuel pump as stated before, but it could also be a clogged fuel filter or a weak starter. Best way to determine if it's fuel related is to hook a fuel pressure gauge to the line and see how many pounds it's pushing upon start up.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 07-04-2006, 10:28 PM
but if it was the fuel filter wouldn't do it all the time? It only does this if I haven't started it for hours.
Old 07-04-2006, 10:39 PM
HiFlow5 0's Avatar
Stanger
Not necessarily, I've seen bad fuel filters cause hard starts and excessive cranking. It's just cheap reasurance to a good running system, even if it isn't bad.
-2013 Ford Flex
-1999 Ford F150
Old 07-05-2006, 12:20 AM
What's the life on a fuel filter? I think this one has about 30,000 miles on it.
thanks for all the help
Old 07-05-2006, 12:38 AM
HiFlow5 0's Avatar
Stanger
Life can be determined by many things. Type of fuel, running your gas tank low and sucking sludge, debris in the take from being old. Either way, 30k miles is way too much life for a fuel filter, I change mine once a year for good measure, and I only put about 8k miles on my car a year.
-2013 Ford Flex
-1999 Ford F150
Old 07-05-2006, 10:15 PM
i replaced the fuel filter. That wasn't the problem. I guess everything points to the fuel pump
