Old 07-01-2006, 11:28 PM
barker23 barker23 is offline
Send a message via Yahoo to barker23
98 blazer odd trouble codes
I am getting some rather odd trouble codes from my OBD-ll reader. One is 1870, one is 8107, one is E504 and the last one is Fd00. Anyone ever seen these before? They arent in my manual for the code reader. Thanks to all.
03 Chevy Trailblazer LT EXT
04 Silverado Z71
88 Fiero Formula V-6
82 Chevy Corvette
07 Dodge Caliber
Old 07-02-2006, 02:14 AM
OverBoardProject OverBoardProject is offline
Banned
Re: 98 blazer odd trouble codes
Here's the first one anyways
P1870 - Transmission Component Slipping
Guy's I looked in Blazee's chart already, just to save you some trouble
Old 07-02-2006, 10:09 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Better pitch that code reader back and get another one.
Or even Auto zone can and will read the codes for free.
But use Caution when getting the free code checks please.
Some parts places do offer free code checks. And also free repair advice. But beware. Just get the code no and post it back here and someone will help you.
They offer the free code checks in the hope of increasing there parts sales.
Almost all of them will also offer mechanical advice and some know what they are doing.
But just remember most of them are parts people pulling codes for free.
Not trained professional tech/mechanics. Even if they pull a 02-sensor code or another sensor related code it does always mean to replace that sensor and your problem will be fixed.
Please just get the code no and post it back here and we will help you.
MT
Old 07-04-2006, 02:06 AM
MT-2500,
I took the Blazer to Auto Zone. The code they got was P1870. Their reader says it the Transmission Automatic 4 wheel drive indicator (lamp) circuit short to battery. Transmission Mechanical transfer case 4x4 switch circuit short to battery.
What the heck does all that mean? Any idea?
04 Silverado Z71
82 Chevy Corvette
07 Dodge Caliber
Old 07-04-2006, 09:44 AM
MT-2500's Avatar
AF - Advisor
MT-2500,
The code indicates that the VCM has detected a transmission component slipping more than it should.
But it does not say what one or what is the root of the problem.
It can be caused by many things from clutch pack slipping to the lockup clutch slipping. Valve body or lockup cliutch or even transmission sensors and controls can cause it.
The only way to pinpoint it is with a good transmission tech with a capable scanner and read out the slippage and sensors.
In your case I would clear the code and see if it returns.
I am not sure what all you added or was testing but it could be a false code.
Also some need a rewire kit on the VCM wiring.
Do a search I think BlazerLT had a post on the wiring kit a while back.
Unhook all of the extra stuff and clear code and see if it returns first.
Also A good transmission service and a good look at the transmission filter and what is in the bottom of the transmission pan would be in order.
Here is just a little info on it.
Info - Component Slipping/DTC P1870 - Diagnosis #99-07-30-005 - (03/18/1999)Table 1: TCC System Symptom Table Table 2: Internal Transmission Symptom Table Component Slipping/DTC P1870 - Diagnosis1996 Buick Roadmaster 1996 Cadillac Fleetwood 1999 Cadillac Escalade 1996-99 Chevrolet Camaro, Corvette 1996-99 Pontiac Firebird 1996-99 Chevrolet and GMC C/K, M/L, S/T, G Models 1996-99 Oldsmobile Bravada 1996-99 Holden Commodore with Hydra-matic 4L60-E (RPO M30) DescriptionMany technicians experience difficulty when diagnosing 1996-1999 4L60-E transmissions with a DTC P1870 (Transmission Component Slipping). The purpose of this bulletin is to provide assistance for technicians that have already completed the DTC P1870 diagnostic table in the Service Manual. This bulletin will provide a diagnostic strategy for solving DTC P1870 concerns as well as give some of the most common causes for a DTC P1870. General Information ImportantChevrolet Camaro, Pontiac Firebird with 3.8L V6 Engine experiencing a slip condition at 70-90 km/h (45-55 mph) when the TCC applies should refer to Corporate Service Bulletin 77-71-70A for calibration re-flash. 1996 Chevrolet and GMC C/K, M/L, S/T, G Models, and 1996 Oldsmobile Bravada with VCM and 4L60-E (RPO M30) with a slip or flare on the 1-2 and/or 2-3 upshift, or no 3rd or 4th gear, or launch shudder should refer to Corporate Service Bulletin 66-71-03A to ensure that a poor internal ground in the VCM does not exist. A DTC P1870 indicates that a mechanical malfunction exists. If any other DTC's set along with a DTC P1870, then diagnose those first. A DTC P1860 (TCC PWM Solenoid Circuit Electrical) will set if a TCC PWM solenoid circuit failure exists. A DTC P0740 (TCC Enable Solenoid Circuit Electrical) will set if a TCC enable solenoid circuit failure exists. When attempting to duplicate DTC P1870, it is critical that a normal operating temperature of 82°C (180°F) to 93°C (200°F) be reached. It may be difficult to attain the transmission temperature required to adequately cause the DTC to duplicate. Allow the vehicle to idle to assist in warming the powertrain. Optimum speed to duplicate the DTC P1870 is between 89 km/h (55 mph) and 107 km/h (63 mph). Commanding the TCC ON and OFF several times with the Tech II is critical to monitoring slip when sticky valves in the valve body are suspect. If the customer brought in the vehicle for a temporary harsh 1-2 shift and no driveability concerns are seen during a test drive, then remember that a harsh 1-2 is a result of the PCM commanding maximum line pressure from recognizing a DTC P1870. The PCM must recognize that a DTC P1870 has set in two consecutive key cycles to illuminate the MIL. If a DTC P1870 is not recognized on a second key cycle, then normal line pressure returns. Vehicles should be inspected for correct tire size, axle ratio, or calibration. Diagnostic ApproachActionYesNoAttempt to duplicate DTC P1870. Did you duplicate DTC P1870?Go to Slip Check ProcedureGo to TCC System Symptom TableSlip Check ProcedureThis procedure will assist in isolating what area of the transmission is causing your slip, either the TCC system or internal transmission components. After you have isolated the origin of the slip, then utilize the TCC System Symptom Table or the Internal Transmission Symptom Table of this bulletin for most common concerns. To check for a TCC system concernTCC slip can occur either hot or cold or in both conditions. First, perform the following test at cold transmission temperatures, then perform the same test at normal operating temperature. Ideal slip from the transmission with the TCC applied is 50 RPM or less under light to normal throttle, no heavy engine load or hard accelerating conditions. Use the Tech II scan tool to monitor TCC slip while driving the vehicle in 4th gear at steady speed with the TCC commanded ON. When the TCC is applied or released (release the TCC with brake pedal, not the scan tool - release the TCC by lightly applying the brake pedal while simultaneously maintaining a steady throttle position), the slip speed should drop or rise 150-300 RPM. If the slip speed does not drop, then the DTC P1870 is being caused by the torque converter system. ActionYesNoDid TCC slip speed drop (150-300)?Continue Slip Check Procedure for an internal trans concernGo to TCC System Symptom TableTo check for an internal transmission concernSlip should be checked in every gear to isolate in which gear the slip may be occurring. Drive the vehicle in each forward gear range D1, D2, D3 and D4. Command the TCC ON with the Tech II in each gear and monitor slip speed. ImportantVehicle speed must be over 11 km/h (7 mph). Some TCC slip is normal when the TCC applies directly after 11 km/h (7 mph) is reached. If the slip speed remains constant from gear to gear, then the condition is most likely TCC related. Example: Slip speed is higher in second and fourth gear than in third gear. This would lead a technician to a possible slipping band. ActionYesNoIs slip speed equal in all gears?Go to TCC System Symptom TableGo to Internal Transmission Symptom TableImportantThese symptom tables are to be used when the following symptoms are associated with a DTC P1870. TCC System Symptom Table SymptomCausesTCC SLIP (100 RPM SLIP)Check for bronze bushing material in the pan and filter. If bronze material is present, then the stator bushings (234) and turbine shaft (241) should be replaced (Bronze bushing may turn black with an acrid odor). The turbine shaft and housing (621) should be replaced if damaged. In rare instances, it may be necessary to check for an overheated torque converter (24) (Blue and/or distorted converter). TCC solenoid (66) - Perform leak check. Converter clutch valve (224) in pump should be checked for 13 mm (0.500 in) of bore travel without binding. Turbine shaft O-ring seal (618) cut. Turbine shaft hole not drilled to full depth. This concern can be checked by squirting trans fluid through the turbine shaft hole to check for full flow. This is a low mileage failure. NO TCC APPLY (300 RPM SLIP)Converter clutch valve (224) stuck closed (Check for debris in valve bore). TCC PWM solenoid (396) broken/cracked. Visually inspect solenoid. TCC solenoid (66). Perform leak test. Turbine shaft O-ring seal (618) omitted. TCC SLIP WITH STALL STUMBLEConverter clutch valve (224) stuck open (TCC is applying).INTERMITTENT TCC, OK COLD, SLIPS HOTTCC PWM solenoid (396). Leak test solenoid. The TCC regulator apply valve (380) and/or converter clutch shift valve (224) may be sticking/side-loading. It is possible there will not be any damage to the valve upon inspection. Transmissions produced after 2/1/98 will have a groove cut into the spring end of the regulator apply valve. This design is to help float the valve in its bore (replace valve body assembly). Internal Transmission Symptom Table SymptomCauses3RD OR 4TH GEAR SLIP3-2 downshift solenoid (394) ball seat retention failed. Leak test solenoid. Usually associated with a 3-4 clutch/band worn. 3rd accumulator retainer and ball assembly (40) leaks. Test for proper check ball operation. Usually associated with burned 3-4 clutch. NO 4TH OR SLIPPING 4TH Check ball in the wrong location or extra check ball that has dropped behind the spacer plate during trans assembly. The extra check ball can block the 4th apply servo feed. Clutch orifice cup plug (238) not fully pressed in. SLIP/FLARE IN ANY GEARPump slide inner spring (207) or outer spring (206) omitted causing a slow slide response.NO 3RDClutch orifice cup plug (238) blown out.HARSH 1-2 UPSHIFT4-3 sequence valve (383) stuck in bore by sediment.NO 2-3 UPSHIFT2-3 shift valve (368) or 2-3 shuttle valve (369) stuck in bore by sediment.NO 3-4 UPSHIFT3-4 shift valve (385) stuck in bore by sediment.Service InformationRefer to the appropriate Service Manual for replacement procedures. Warranty InformationLabor Code: Refer to Labor Time Guide for correct labor operation. Please use the closest available labor operation for the diagnosis performed. GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION© Copyright General Motors Corporation. All Rights Reserved. --------------------------------------------------------------------------------.
This one here is for newer 2000 up but has good info on testing.
Diagnostic Information on DTC P0894 and P1870 #02-07-30-001A - (02/11/2004)
2000-2004 Passenger Cars and Light Duty Trucks
2003-2004 HUMMER H2
with 4L60-E or 4L65-E Automatic Transmission
This bulletin is being revised to include additional model years and additional diagnostic information. Please discard Corporate Bulletin Number 02-07-30-001 (Section 07 -- Transmission/Transaxle).
Diagnostic trouble codes (DTC) P0894 and P1870, Transmission Component Slipping, may have different root causes. The following diagnostic tips are provided to assist in accurately repairing the condition.
Corporate Bulletin Number 01-07-30-023A, dated November 2001, is intended for 1996-1999 vehicles with more than 32,000 km (20,000 mi). This bulletin addresses wear in the valve body TCC isolator/regulator bore, which can cause DTC P1870. This wear condition is not the cause of DTC P0894 or P1870 on any 2000 model year vehicle built after January 15, 2000, or any 2001 or newer vehicles as the valve body used on these vehicles has been revised to prevent the wear condition.
Corporate Bulletin Number 99-07-30-005, dated March 1999, should be used to help with diagnosis of these DTC's. This bulletin will help to determine if the DTC is caused by the TCC system or by a slipping internal transmission component such as a clutch or band.
Slip speeds greater than about 250 rpm at steady state driving are caused by a slipping clutch or band.
Slip speeds below 250 rpm at steady state driving are usually caused by the TCC not applying but may also be caused by a slipping clutch or band.
A plugged or restricted TCC apply fluid orifice (238, located in the pump) may cause DTC P0894 or P1870, especially in low mileage vehicles with less than 8,000 km (5,000 mi).
A converter clutch valve (224, located in the pump), which does not have full travel of 13 mm (0.5 in) or is stuck in the off position may cause DTC P0894 or P1870. Inspect the valve for chips, debris, nicks or burrs. Also, inspect the springs (225 and 226) to make sure they are not limiting valve travel. A spring that is not fully wound may catch in the bore, limit valve travel and cause DTC P0894 or P1870.
A cracked or leaking TCC solenoid (part of harness 66) may cause DTC P0894 or P1870. Use solenoid test kit J 44246 to test the operation of this solenoid.
A cracked or leaking TCC PWM solenoid (396) may also cause DTC P0894 or P1870.
When attempting to diagnose a DTC P0894 or P1870, it is important to also refer to the appropriate Service Manual for further possible causes of this condition.
MT
