Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 07-01-2006, 11:07 PM
civicrunner07 civicrunner07 is offline
Send a message via AIM to civicrunner07
Help with swap problem....
ok so a buddy of mine and I just swapped a B18C1 into his 98 civic EX. Everything runs awesome, but the only problem is it burns about 4 quarts of oil every 3000 miles, and the strangest part is we can't find an oil leak anywhere we were thinking it might be the rings. anyone els have any other ideas as to what could be causing the problem....
thanks
Old 07-02-2006, 10:02 AM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: Help with swap problem....
is it smoking bad? because losing that much oil that quick is no where near normal...
Old 07-02-2006, 05:18 PM
no not that i know of.
Old 07-02-2006, 07:13 PM
Kind of a Big Deal
well, youd know it if it was....so that tells me there is a leak somewhere... i would washt the engine down real good and top the oil off. then run the car for a while (dont drive it cuz then the air swerling in the engine compartment may move the oil stream..) and shut the car off and let it cool dow then try and find the spot that has the oil...
Oh ya....is there any oil in your engine coolant?
Old 07-02-2006, 09:08 PM
i dont know about the coolant because it's not my car and i havent seen him since he's started having the problem. i've just heard about it..... if there was oil in the coolant, what would that mean?
Old 07-03-2006, 05:44 AM
Kind of a Big Deal
head gasket most likely
Old 07-13-2006, 04:26 AM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
i had the same problem. but not that bad. it turned out to be a piston ring and my head gasket. do a compression test. and i would change the head gasket.
-tony-
2000 honda s2000
