Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 07-01-2006, 05:08 PM
TeamRedLine23's Avatar
TeamRedLine23 TeamRedLine23 is offline
Send a message via AIM to TeamRedLine23
transmission oil mix with motor oil?
what are the side efects of useing transmission fluid mix with motor oil? I know tranny fluid will clean the oil deposits and all that good stuff. This guy with another gst mixed tranny fluid with motor oil and now his car does nothing but blow white smoke and sometimes blue. what does this mean? thanks agian.
1997 Eclipse GS-T
Performance modification:-evo3 16g-K&N Intake-HKS SSQV b.o.v vented-2.5'' Dejon tool blow thru upper and lower-Dejon large smic-GM MAF-MAF Translator-HKS 3" Carbon Fiber Titanium TBE-stock fuel rail-Walbro 190 fuel pump-PE 650cc injectors-Accel Thundersport wires-NGK series 7 spark plugs-1g intake mani/head-
Interior Modification:-Autometer Boost Gauge
http://www.cardomain.com/id/xTeamRedLine23x
Old 07-01-2006, 05:57 PM
SLoe's Avatar
SLoe SLoe is offline
Re: transmission oil mix with motor oil?
Do you mean putting it in the crankcase? Don't do that!!
ATF will clean the deposits on the inside of the cylinder when you let the motor ingest it, but it has a different viscousity than motor oil. How much did he mix? Might damage bearings, and or rings, IDK. White smoke is water though so I don't think that has anything to do with it.
If he mixed oil and ATF and then let the motor suck it in, then it shouldn't have affected anything.
Just stick with the motor oil in the crankcase, and you won't have to worry about what the effects are.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 07-01-2006, 06:57 PM
I it was dexron 3. and he put a quart in
1997 Eclipse GS-T
Old 07-01-2006, 06:59 PM
oh and he used I think it was royal purple 10w30.
1997 Eclipse GS-T
Old 07-01-2006, 09:15 PM
SLoe's Avatar
IDK, I have never met anyone who has done something so retarded before..... did you slap him yet?
Old 07-01-2006, 09:23 PM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
1 quart is way to much to add, he possibly could have fucked his engine up
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD [email protected] (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
Old 07-01-2006, 09:57 PM
kjewer1 kjewer1 is offline
AF - Advisor
If you want to mix something with the oil, or even run it through the intake, try Marvels Mystery Oil, it's good shit. I run a half quart for the 500 miles before each oil change is due. I've run it in old motors that I opened up before and after using it, so I have a good idea of its effects, I just don't feel like rambling on about it at the moment. It should burn better than ATF. You can even add it to the fuel (most poeple running toulene also run MMO). I don't like the ATF idea. Some poeple do run it in the oil to clean out the lifters, but you arent supposed to go WOTing around on it Just idle and a little revving perhaps.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-02-2006, 10:50 PM
ok, so its a bad idea. and yes I will slap him. but from what I understand from kjewer1 its still not a good idea but its ok if the car is just sitting in the driveway and he starts it every other day to let it idle? i really need to tell him about this forum.
1997 Eclipse GS-T
Old 12-01-2012, 05:15 PM
vicboyz vicboyz is offline
i need to figure out wut size the tans full dipstick is for a 88 ford crown victoria its crack on the bottom of the pole and its leaking out
Old 12-01-2012, 06:29 PM
SLoe's Avatar
Cincinnati (see I can do it too)......IDK, go order one from the Ford dealership. 6 year old thread back from the dead. Is this the zombie apocalypse? I thought we had a few more weeks before that happened.
Old 12-02-2012, 09:02 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Seriously dude? Not only are you in the completely wrong forum, but also this thread is 6 years old and has nothing similar to your problem at all. You need to go to the right subforum for your car and search in there or start a new thread about you issue.
-Silvr
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
