Old 08-07-2002, 01:02 PM
kush187 kush187 is offline
Send a message via AIM to kush187
Unhappy Interior lights not working HELP!
For some reason my interior lights and trunk light arent working. I checked the fuses and they look fine. What else can I do to fix this problem????
Old 08-07-2002, 02:46 PM
nittanys1's Avatar
nittanys1 nittanys1 is offline
Send a message via AIM to nittanys1
u sure you checked the right fues?
Old 08-07-2002, 03:04 PM
luti luti is offline
Send a message via AIM to luti
Check the bulbs?
T3/T04E turbocharged ricer.
Old 08-07-2002, 04:18 PM
I checked...
I checked the bulbs and fuses again
Old 08-07-2002, 07:19 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Probably a connection problem somewhere... I would recommend getting a volt-meter and checking the voltages at various points (like at the door-switches, etc).
Old 08-09-2002, 02:39 PM
Duatone Duatone is offline
yeah, i agree, just starting shoving a volt meter in all your holes. well, electrical types that is. and im an echo, but you did check all the fuses? panel and under the hood?
so far:
1990 accord ex
JDM F22B DOHC/Nakayama cold air intake/Nakayama exhaust/18" Enkei Zoku painted black/Yokohama Parada Spec II/Full air ride/shaved doors & mouldings/VIS R34 front bumper blah blah blah...
Old 08-09-2002, 04:09 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
If something was working, and now it's not ........ either a wire has come loose, you've blown a fuse or the item is broken
Old 08-09-2002, 09:53 PM
ci5ic's Avatar
LOL... that doesn't really narrow it down at all hahaha.
Old 08-10-2002, 02:42 AM
spy54's Avatar
spy54 spy54 is offline
Send a message via AIM to spy54
thank you captain obvious
AF Teen Crew
Purehonda.com - may she rest in peace
1996 Chevy C1500, Flowmaster Exhaust, Tinted Windows, 2 Kicker 10" L7 Subs, Eclipse 5v headunit, Alpine V12 Amp
DJM 4/6 drop kit being sold
Full Throttle 9.5 inch lift being installed
1989 CRX si "silver mist"---SOLD---.....Stripped and Wrecked in Compton
corbeau forza 2 seats, DC short shifter, Powerslot slotter rotors, AEM brake pads, Bfgoodridge Stainless steel brake lines, Greddy MX exhaust, AEM Cold Air Intake, Konig Rated-R rims, Kamikazi header
Make an Offer [email protected]
Old 08-13-2002, 11:57 AM
Audio Guy
I was meaning in the effected circuit(s). So many people freak out and go crazy, checking/replacing crazy stuff that has NOTHING to do with the problem. Use a multimeter to check the bulbs - should be some reading on the 200 ohm setting. Check ALL the fuses - God only knows what you have tapped into for your stereo stuff, so I have absolutely no idea where to start there. All of that shouldn't take but 10-15 min. If no luck, then you have pulled a wire loose some where - good luck on finding something like that.
HELP- 2002 Explorer Eddie Bauer- Radio, Interior Lights Not Working, No Fuses Blown? blazzingbrandon Explorer | Explorer Sport Trac 2 11-05-2008 09:22 AM
Interior lights not working/new cd deck wont work Ranjah Sable 1 04-30-2006 01:18 AM
Blower motor only works on full & interior lights not working rburwood 7 Series 2 02-26-2006 01:49 PM
'98 Suburban; Interior lights not working Mrk C/K 8 02-19-2004 09:09 PM
2000 Blazer Interior Lights Not Working JJBRD Blazer 0 01-27-2004 11:27 AM
