Old 07-01-2006, 03:24 PM
666_speed's Avatar
666_speed 666_speed is offline
Son of Satan
Ring and pinion gear question...
Will a broken/failing ring and pinion gear cause the SES light to flash? I stopped at a red light and when it turned green I made a right turn and half way through the car started making a sound like it had a flat tire. I pulled over and checked all the tires and they were all okay. I've been suspecting the gears to go out anyways...any other ideas? Thanks.
Old 07-02-2006, 12:13 AM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: Ring and pinion gear question...
I don't think it would be setting a SES light but a brake light should go on cause if your ring gear was missing teeth the pinion/VSS sensor would be spinning faster than the reluctor ring on your ring gear was spinning and it may set a code but I doubt it.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 07-03-2006, 08:43 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Originally Posted by FormulaLT1
the pinion/VSS sensor would be spinning faster than the reluctor ring .
The VSS is part of the long term fuel trim calc, that will set a code in the PCM and trip the SES light.
