Go Back   Automotive Forums Car Chat > Buick > Regal
Old 07-01-2006, 12:52 PM
xyinati xyinati is offline
Hello All Problem w/91 regal custom no codes PLS HELP
ok here is my problem w/ my 91 regal 3.8 custom. I have already replace ICM.ECM,MAF, plugs and wires check all the connections and I still have a problem. After about 10-15 min after its been running it starts to bucks and sputter when I push on the accelrater. It idles fine even after the problem starts. I have check the codes and get nothing. Please can someone HELP ME.
xyinati
Old 07-01-2006, 04:00 PM
maxwedge maxwedge is offline
A990 racer
Question Re: Hello All Problem w/91 regal custom no codes PLS HELP
xyinati
Welcome to AF, your description is a little brief, is this under load, at high speed low speed? Try disconnecting the maf when this happens see if there is any change, check your connections at the maf, icm and crank sensor harnesses for corrosion or poor connections.
Old 07-01-2006, 09:22 PM
Thanks you very much maxwedge for the reply I have check all. All the connections are tight,and no corrusion.I drove it till the same problem has happened. I unpluged the MAF and nothing. The car doeest stall at all just bucks and sputters when I push normally on the gas. If I press it to about (dont now for sure automatic)300-700rpms It bucks and stutters some, but I can some times keep moving very very slowly, and as soon as I let off the gas it idles normal.
Old 07-02-2006, 06:48 PM
A990 racer
Lightbulb Re: Hello All Problem w/91 regal custom no codes PLS HELP
So it runs the same with or without the maf connected, if so I'd try another one, fuel pressure is good I assume.
Old 07-05-2006, 08:42 AM
91RegalOwner 91RegalOwner is offline
Sounds like I might have the same problem. Described the problem to my mechanic and when he came over he knew right away it was the Throttle position sensor. Haven’t fixed it yet as I’ve yet to purchase the part.
My 91 regal 3.8L ran fine until 2 months ago and then it would sputter and stammer and then wouldn’t start again. If I let it sit for a while it’ll start again but after 2 or 3 minutes it starts to sputter. RPMs go wild and when I press on the gas the amount of pressure on the pedal does not relate to rpm’s rising accordingly. Fuel pump seems to work fine – I hear it when I turn the key in the ignition prior to starting. Fuel filter needs to be replaced – haven’t done so in 5 years but not sure if that would be the culprit. 200,000KM on the engine so far…
Anybody else?
Old 07-10-2006, 09:48 PM
In case any body is reading this post it turns out that the TPS was not the culprit. I took apart the throttlebody, replaced the TPS and cranked the engine. Still a problem. Then by chance I unplugged the MAF sensor and cranked the engine. BINGO. Engine was running smooth. I replaced the old TPS and put everything back together and kept the MAF sensor unplugged... this was just to make sure the MAF sensor was indeed the problem. and it was.
Seeing that the MAF sensor at my dealership is 300+CDN (used part is roughly 90bucks) does anyone know if these sensors are repairable? What normally goes wrong with these things? AND - how do i know it's the sensor itself and NOT the wiring attached to it? Is there a way to test the sensor itself?
Any help is appreciated - you'd be helping me save big bucks so please reply!! thanks!!
Old 07-11-2006, 03:14 PM
A990 racer
Talking Re: Hello All Problem w/91 regal custom no codes PLS HELP
See you took my advice, good, I think you did anyway, parts houses can sell a reman unit, they can be iffy though.
Old 07-12-2006, 02:01 AM
Vandy 1 Vandy 1 is offline
I don't know how to test the sensor nor if they are repairable but FYI
Parts America / Checker Auto's online store shows a new MAF sensor for
your car {2 different ones} from $122--$160. This price is from stores
in Phoenix, AZ.
