Old 07-01-2006, 12:39 PM
batman3390 batman3390 is offline
Are there any micromesh alternatives
Please tell me there are micromesh alternatives. My mom will not let me order these things on the net.
Old 07-01-2006, 01:57 PM
freakray freakray is offline
AF Modelrater
Re: Are there any micromesh alternatives
You're referring to Micromesh polishing cloths, right?
Firstly, are you looking for them to polish with, if that's the case, they're not necessary. Get yourself some 3M Rubbing Compound in the fine cut solution and use that as an alternative. It's available from most auto parts stores.
AF User Guidelines
Old 07-02-2006, 11:24 PM
well..i asked earlier about my 320 grit sandpaper. apparently its too rough for what were doing. Is micromesh only for polishing. what about sanding prior to polishing.
Old 07-03-2006, 05:02 AM
cyberkid's Avatar
cyberkid cyberkid is offline
The most commonly used high grit (400-2000) wet-dry sandpaper is Tamiya's.
Micromesh also has the same grits but goes way finer. I've never used Micromesh before so all I can tell you is what I have read or heard. Tamiya's 2000 is somewhere near Micromesh's 3000. Micromesh also makes 150-12000grit sandpapers. So in reply to batman3390 you could go all the way using Micromesh but its harder and more expensive to get than Tamiya's.
So, what I would do is: use Tamiya's up till 2000 then switch to Micromesh's.
One note: grits 150-600 will do quite a bit of damage to your model. These grits are mainly used for cleaning up sprue joints, mold lines and scratch building.
HTH,
Steve
Please read the following linked articals before posting a question.
Once you have and still have questions, try to post your questions clearly.
This will make a lot of people's blood pressure drop back to normal, including mine.
NEW TO THE AF MODELLING FORUM? PLEASE READ THIS FIRST
AF Car Modeling Tutorial, How-To and Product Review Depository
AF Car Modeling Frequently Asked Questions [FAQ] - * Look here first! * ver2.0
And finally,I wish you all happy modeling
