Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 07-01-2006, 11:44 AM
tsoperator tsoperator is offline
'92 Cutlass brake problem
Hey everyone,
This is my first post and I have a question. It seems like forums like these are a great place to find good information from people who know, so any help will always be appreciated.
Anyhow, my folks have a '92 Cutlass Supreme 3.1 and the brakes are just terrible. When I've driven it you have to stomp on the brakes to get it to stop quickly. A lot of pressure is required in everyday driving. My folks spoke with an olds mechanic and their mechanic who both said that's just how the brakes are for this year and model.
Anyone heard of this? Is there any solutions?
Thanks, Jesse
Old 07-01-2006, 02:48 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: '92 Cutlass brake problem
Welcome to AF!!
I disagree with your mechanic! This is not normal for any braking system. First of all you need to have the brakes checked. It sounds like you have either a problem with the master cylinder or the power brake booster. You may also need to have the brake fluid replaced due to low boiling point.
Old 07-01-2006, 04:43 PM
maxwedge maxwedge is offline
A990 racer
Lightbulb Re: '92 Cutlass brake problem
Originally Posted by tsoperator
Hey everyone,
Thanks, Jesse
Also take a careful look at the rear disc brakes, the calipers and slides are famous and infamous!! for seizing up causing the front brakes to do all the work, jack 'er up, step on the brakes and see if the rears lock up, carefully of course.
Old 07-01-2006, 08:28 PM
Thanks for the welcome!
I'll get with my dad on these topics. I believe he had the brakes done recently so I don't know if a bad master cylinder would be apparent when this is done(I've done little work on cars). I'l start looking into these and keep you posted...thanks for the help!!
Jesse
Old 08-01-2006, 01:02 AM
bladekinslayer bladekinslayer is offline
I have a 92 olds supreme.
the brakes do take more pressure than 'a normal newer car' to stop. Thank GM for crappy 10.5" rotors system.
I do get a little brake fade sometime on hard stops.
But what you say seems extreme.
I had this happen to me it was the rear calipers siezed up (YES BOTH!! Thank GM again for poor caliper design!). I'd start there and make sure there not siezed. If there ok then check the mastercylinder/booster.
I got rid of the problem entirely by upgrading to a 94+ rear rotor and caliper.
(11" rotor & pads way easier to change).
The car stops much better now. Gonna do the front upgrade to 11" this week I hope.
Hope this helps
