Old 07-01-2006, 10:54 AM
anterano anterano is offline
White smoke only on startup with low coolant
My truck has quite a bit of white smoke only on startup. I noticed it was getting rather hot. Upon checking the coolant I noticed it was low. After I filled it backup it seemed fine. But when I checked back later it seemed low again. I had checked where I parked for signs of leakage but did not find anything. Where do I start? Thanks in advance!
Old 07-01-2006, 11:17 AM
broughy84's Avatar
broughy84 broughy84 is offline
Re: White smoke only on startup with low coolant
I would start with a coolant system pressure test and leak down. Then possibly a compression test to narrow out the possiblity of bad head gaskets. What year is it and what motor? The Vortec 350's are bad about intake gasket leaks.
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 07-01-2006, 06:05 PM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
no foam or milk in the oil right ?
do a leak down test
sounds like it is leaking into an intake runner or into a cylinder after its shut off
but if it gets to much into the cylinder and you go to start it and the piston compresses that water and prevents the piston from coming up(hydraulic lock) then you can have a big problem with a rod bearing
sounds like it is time to park it until its fixed
good luck
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
Old 07-01-2006, 06:19 PM
Its a 91 v6 original engine. Is there a way to check the oil without having to drain it?
Old 07-03-2006, 10:55 AM
broughy84's Avatar
Pull the dipstick, like just checking oil level....
If it is really foamy, or looks like chocolate milk coolant is leaking into the crankcase somewhere. Anyway, I agree with the above poster try a leak down test, and check the oil, let us know what you find and we will try to help.
Matthew Brough
Old 07-04-2006, 10:30 AM
I haven't done the leak down test yet. But when I checked the oil it looked normal.
