Old 06-30-2006, 10:43 PM
Decipha Decipha is offline
bad head gasket
changed: radiator, thermostat, thermostat housing, elbow (heat exchange tensioner), and the water pump.
car still runs hot... popped the cap off the radiator and smoke came out, smelled just like the exhaust tip... anybody got any idea what could be wrong? cat still has power, no misses, no water in oil, nothing that would indicate a bad head gasket... any advice is greatly appreciated
sry mods i'll try 2 b good
Old 06-30-2006, 10:44 PM
Re: bad head gasket
^^car still has power**
Old 07-01-2006, 12:20 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: bad head gasket
What year Grand Prix is this and what engine?
Have you confirmed whether the thermostat is opening and are the cooling fans kicking in? What is the temp gauge reading?
Timeslip 08/12/06
AF Community Guidelines
Old 07-01-2006, 01:52 PM
Re: bad head gasket
97 gt 3.8 non sc
yup thermostat opens right at about 160 and the fans kick on when the a/c is on temp gauge reads right above 210, the coolant isin't circulating like it should its kicking the water out the radiator and lots of smoke, not steam, SMOKE like exhaust smoke
Old 07-01-2006, 01:58 PM
BNaylor's Avatar
Re: bad head gasket
Originally Posted by Decipha
97 gt 3.8 non sc
Bummer! Doesn't sound good. Are you losing any coolant?
I'd run a compression test to confirm whether it is the head gaskets but it is starting to sound like that or maybe a warped or cracked head.
Timeslip 08/12/06
Old 07-01-2006, 02:31 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: bad head gasket
I'd install an air fitting into the sparkplug hole and hook it up to shop air. Then pull off the radiator cap and look for bubbles. Both valves have to be closed for this to work..
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
