Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 06-30-2006, 09:27 PM
wallacestac wallacestac is offline
Fuel Pressure Problems
I have a 94 Jeep Wrangler(4.0 MFI). Recently it started to take several cranks to start the engine. Now once it gets to operating temperatures, it is extremely difficult to start after you shut it off. I suspected fuel pressure problems. Fuel pressure is at 28 psi with the vacuum line on or off of the pressure regulator. After installing a new fuel pressure regulator it remains the same. The vacuum lines do not have any leaks, blockages, or kinks. The engine runs fine above low idle. Once it warms up, it runs a little rough at low idle after sitting still. Any suggestions.
Old 07-03-2006, 08:01 AM
tomvid tomvid is offline
Re: Fuel Pressure Problems
It could be the crankshaft position sensor.
Search this site. There are alot of posts about it.
Mine was taking a couple extra cranks to start and that fixed the problem.
Old 07-06-2006, 03:16 PM
myjeepsux420 myjeepsux420 is offline
Send a message via MSN to myjeepsux420
The CPS has nothing to do with the fuel pressure. You should have 45 psi with key on, not running. I bet your pump is about to go bad, or you have a crappy filter. Likely the longer and hotter your pump is running, the less PSI it can supply. You should have over 45psi while at idle.
1995 Jeep Wrangler
3 1/2" lift 33x12.50 tires
4.5L stroked I-6
Bored throttle body & Cold Air Intake
Jet Chip Stage 2
Jet Thermostat
Colorado Off Road Rig!!!
Old 07-06-2006, 10:23 PM
Thanks. it was the fuel pump.
