Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-30-2006, 06:58 PM
musicman181 musicman181 is offline
valve cover bolts
while trying to change my valve cover gasket i stripped the last bolt, so there's only one bolt left on it. is there anyway i can get is off, it seems to be stripped in two of the eight corners of the bolt, or can i use some sort of sealant to keep my cover from leaking? thanks you guys
civics are for suckas
95' eclipse gst
stock turbo
new C.A.I.
programmed ecu
2.0 DOHC manual
greddy bov
im workin on it. slowly but showly
Old 06-30-2006, 09:15 PM
Blaiser17 Blaiser17 is offline
Send a message via AIM to Blaiser17
Re: valve cover bolts
Permatex gasket maker ($4.99 at Advanced Auto for a tube), or drill the hole and tap it, but gasket maker would be easier.
1999 Chevy Monte Carlo 3.1L
1991 Chevy Camaro 3.1L
1981 Chevy Camaro z28 383 Stroker
2000 Mercury Cougar v6
Old 06-30-2006, 11:00 PM
EricSchnabel EricSchnabel is offline
i would say drill and tap it but you can replace the bolt with any ordinatar bolt it doesn't have to be the $8 bolt from a dealer. I snaped one of those in half and had to get it out with a screw driver and a hammer it took at least an hour and i put a normal bolt in it and it hasn't leak any oil or anything.
Old 06-30-2006, 11:40 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Wait, did you strip out the threads or did you round off the bolt head?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 07-01-2006, 08:06 AM
ned032002's Avatar
ned032002 ned032002 is offline
I think the bolt is just jacked so he can't get it out, did you try vice grips? Also aren't there only 6 sides on the head of any bolt, hense the 6 point and the 12 bolt sockets?
Old 07-01-2006, 06:21 PM
SLoe's Avatar
SLoe SLoe is offline
Go to Wal-mart, they carry sockets for removing bolts with "stripped" heads. Just hammer it right on, and it works by the same principle as a screw extractor.
Next time 6pt. bolt = 6pt. socket.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 07-01-2006, 06:34 PM
ned032002's Avatar
Thanks for clearing that up lol
Old 07-01-2006, 06:53 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
gator grip. I use mine all the time for most bolts.
now - 2000 civic
soon - 2002 is300
