Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 06-30-2006, 04:31 PM
JRRNTolkien JRRNTolkien is offline
Weird problem - motor cutting out
For some odd reason, when I hit the dimmer switch on the steering wheel, the motor cuts out for about a second, then resumes. Any idea what could be causing this?
Thanks.
Old 07-06-2006, 09:20 PM
12Ounce 12Ounce is offline
Re: Weird problem - motor cutting out
I hope you find a solution .... and post it. This is a unusual problem.
You didn't mention what year model it is.
But if I had to make a wild stab at it .... I would say somewhere you are missing a ground circuit. If it's a recent model, I would further guess a ground near the PCM module.
Old 07-06-2006, 11:21 PM
Oops. 1985 Bronco II.
Old 02-16-2009, 10:10 AM
martylephew martylephew is offline
I had a similar issue a few weeks ago. When I dimmed my headlights, the engine backfired. I found a ground connector near the battery (male/female plug) that was pretty masty. I cleaned the battery cables and this ground connection and the backfiring went away.
Old 02-16-2009, 03:12 PM
Mine turned out to be a short inside the steering column somewhere. Cost me a hundred bucks to have a wire spliced.
