99 Alero Head Gasket
Need advice-
My girlfriend owns a 99 alero. We replaced the thermostat houseing after we were told it was corroded. Then a week later we are told that we have a blown head. The first estimate was around 1600 and now being told 2200. I dont know much about cars or repairs but the shop does work for one of my coworkers and does a good job. I am waiting on the fax estimate. Does that sound around right or can someone tell me where I may look to find any other information. THANKS
Re: 99 Alero Head Gasket
Thanks for the reply. I have not seen the estimate yet as the guy was supposed to fax it to me and then he did not send it over. I will wait and look at the fax and then follow up with this forum. This site is great.
Here is the estimate I got back on the head gasket job:
Parts 452.00 Machine Shop 465 Labor 1192 Does that seem fair or should I try someone else
How do you know it is the head gaskets and not the lower intake manifold gaskets causing your problem? That still sounds like a rip off even for a head gasket job. $465.00 for machine shop....what the? ![]()
It is for the 3.4 with 105,000miles. I was just told it was blown head and the whole thing needed to be replaced. The machine shop is used to balance everything to make sure everything is fitted correct or so I was told, to make sure all gaskets in place and seals working fine????????????
Are you getting a new cylnder head? Auto machine shop services is used to recondition old cylinder heads. Checking for warpage, deck height, valve job, etc. It sounds like they are farming that type work out. Are you really willing to pay $2109 which is about half of what your Alero is worth? You can get a complete remanufactured engine for less that.
Thanks for the replys--
Here is the latest I have found another shop closer to me that says It is an 11 1/2 hr job 250-350 for parts 125-150 machine shop He said that there is no way that the machine shop should be that High I think I will give them a shot. I was told from the other place that they did a block test and this is what told them about the heads. |
For my alero also a 99w/ a 3.4. It took a privet auto shop 8 hr and 450 bucks total. That is out the door.
We paid about $900 at the dealership and they charged $105/hr.
it is cheaper to buy remanf heads for the 3.4 around $350(pair)plus tradein.
With machining, new valves/seals removing broken exhaust bolts, I could see them charging $450! It shouldnt cost more than $1500 for the total job. $2200 thats ridiculas!
1999 Grand Am SS 3.4 OHV
