2000 z71 5.3 Rough shifting
Truck is starting to shift real rough between 1st and 2nd. Getting whiplash.
It seems to do it after the truck has been running and had time to heat up..Anybody had this problem? 2000 5.3 auto trans with about 80k on rebuilt tranny |
Re: 2000 z71 5.3 Rough shifting
If it has a code P1870 stored, there is a TSB on it.
P1870 is trans slippage. Anytime the computer detects slippage, it raises line pressure to max, and shortens all the shifts to save the transmission, but only for that run cycle. You say it only occurs after running warmed up, so I think the bulletin applies to you. There is a problem with excessive fluid leakage in the torque converter clutch circuit of the valve body. The bulletin gives the number to a replacement valve body. Ask your dealer to look it up. |
And like what one of a thousand ones are you refering to. What tsb no and date and how do you know it applies to this one? And remember the poster said this is a rebuilt transmission. As maxwedge says first thing is to get it on a transmission engine capable scanner. First Find the problem and then find what is causing it.
