Old 06-30-2006, 08:08 AM
gjhunter01 gjhunter01 is offline
Tach/dash light, 1999 Grand Am
I have a 1999 Grand Am GT. Does anyone know the procedure on how to replace the upper tachometer dash light? Also, what is the bulb size I will need to get?
Old 06-30-2006, 01:30 PM
Kidlex01 Kidlex01 is offline
Re: Tach/dash light, 1999 Grand Am
you will need to remove screws under neath your steering cloumn to remove the plate that sits on top, so you can get to the screws that hold the cluster in, remove the two screws that are inside the bezel that sits around the cluster, then remove the top bolts on the cluster and bottom ones and you should be able to remove the instrument panel cluster, turn it over and find the bulb you need to replace.
I dont know the size of the bulb ive never had to replace it, i only have a manual for a 2001 GASE .
Be careful when your taking the back cover off the cluster the tabs break easily.
