Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 06-30-2006, 06:47 AM
SteveY67 SteveY67 is offline
Brakes On a 2001 Impala
I am changing the front brakes on my 2001 impala and I have removed the calipers and now I am not sure how to get the rotors off? I have done this on my 2002 Sunfire and the rotors came off easy, but these rotors are on good. Anyhelpwould be appreciated.
Thanks
Steve
Old 06-30-2006, 08:51 AM
maxwedge maxwedge is online now
A990 racer
Re: Brakes On a 2001 Impala
Thanks
Steve
Welcome to AF. Must be stuck on the hub, get some rust penetrant around the hub to rotor mounting area, give it a few minutes then use a hammer to loosen them from the hub, be careful here if you plan on reusing the rotors.
Old 06-30-2006, 02:49 PM
tractorboy's Avatar
tractorboy tractorboy is offline
If you strike the rotor with a hammer , use a block of wood inbetween the hammer and rotor. Sometimes there are sort of like lock washers on the studs to hold the rotors in place durring assembly. Will the rotors move at all or are they stead fast to the hub. Or are they loose and you can not get them off ?
Old 06-30-2006, 02:53 PM
bigrod118's Avatar
bigrod118 bigrod118 is offline
Thats what rubber and deadblow hammers are for
You took off the caliper bracket right?
Old 06-30-2006, 04:48 PM
Well, I sprayed around the hub and left it, and had a friend help who knows this stuff, and it was just rusted around the hub real good. Nothing brute force and a big hammer couldn't fix :-)
New rotors and pads installed, all is good!
Thanks, and great forum!
Steve
