Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 06-29-2006, 10:10 PM
inatalonIXLR8 inatalonIXLR8 is offline
Will DSMlink work for a 2.4?
I'm in the process of making my dream happen. A 4G64 bottom end with a 1G head with tons of performance parts including a Garrett GT35r/40 turbo. I have been looking at different stand alone engine management systems but have come to realize that this project is becoming more expensive than I had anticipated.
Will DSMlink be able to accomodate this project with a gm MAFT?
P.S. I really apreciate everyones help, but unfortunately I have to head back out in the oil patch again at 5 am so I may only be able to answer a few questions tonight before I hit the sack.
Thanks.
95 Talon Tsi AWD 5spd
2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
Old 06-29-2006, 11:26 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Will DSMlink work for a 2.4?
DSMlink works fine with that type of setup, hundreds of people already doing it.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 06-30-2006, 07:41 AM
Do all the cold start up features, idle control ect work on a completely different engine? I sure hope it would work, but I've got a sneaky suspition that it won't.
Old 06-30-2006, 08:13 AM
AF - Advisor
IF you are talking about simply running a 2.4 bottom end with a turbo head and turbo car, there is no problem. All of the sensors are the same, so I'm not sure where the confusion is. The ECU doesn't really care if you add a little more displacement, the airflow sensor picks it up just fine. I ran a setup like this for years.
Kevin Jewer
Old 06-30-2006, 09:51 AM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
i dont think it would work on the sohc 2.4 in the nt spyders but it will work fine in your tsi since its the same wiring as the 2.0.
im not sure if its compatible with that wing though.....
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 06-30-2006, 01:43 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
In a talon:
Dude, where the hell have you been. Good choice going 2.4 though, lol!
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
