Old 06-29-2006, 10:36 PM
hcivic hcivic is offline
timing on 87 camaro
how do you know car is in time before starting car?I changed the cam and want to check timing before i start it. Will it hurt motor if i start it and timing is off?
Old 06-30-2006, 12:10 AM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Re: timing on 87 camaro
No, but the car will run a bit bad, depending on how badly the timing is off.
Old 06-30-2006, 02:29 AM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Advancing ignitioning timing too much will cause knocking which is harmful to your engine. So yes, depending if it is retarded or advanced and by how much. It could be harmful.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 06-30-2006, 10:00 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
By marking reference points on the dist, mating surface, and rotor when you took it aprart and putting it bak the same way.
Old 07-01-2006, 04:00 AM
Morley Morley is offline
Pull the #1 spark plug. Put your thumb over the hole. Using a1/2" drive ratchet or breaker bar, slowly turn the engine over (clockwise looking from the front) until you feel the air trying to blow your thumb out of the hole. Keep slowly rotating while watching your timing mark. when it reaches 0, stop. set up your distributor & oil pump shaft so that when you drop the distributor in the rotor will point to the #1 terminal on the cap. Install the cap and wires. Triple check the wires to make sure they are going to the right plugs and cap terminals. Start the car and set the timing like normal.
