Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-29-2006, 09:08 PM
Blaiser17 Blaiser17 is offline
Send a message via AIM to Blaiser17
Coolant
I have a simple question. There are two hoses coming out of the engine coolant cap. One goes to the thermostat housing, and is the other just a drip hose for overflow? Or does it actually connect somewhere too? Thanks for your help.
1999 Chevy Monte Carlo 3.1L
1991 Chevy Camaro 3.1L
1981 Chevy Camaro z28 383 Stroker
2000 Mercury Cougar v6
Old 06-29-2006, 09:18 PM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
Re: Coolant
yes
Old 06-30-2006, 11:01 AM
EricSchnabel EricSchnabel is offline
Re: Coolant
If it is the other hose from your coolant reserve it suppose to just hang so that if it gets to full it can empty.
Old 06-30-2006, 03:01 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: Coolant
The other hose should go to coolant resevoir. (sp?)
now - 2000 civic
soon - 2002 is300
Old 06-30-2006, 11:55 PM
Re: Coolant
I had to just replace my radiator cap because when my engine got hot the coolant would flow into the reserve but when it colded down it would suck air in instead of the coolant from the reserve so i had air in my lines.
Old 07-01-2006, 09:09 AM
ned032002's Avatar
ned032002 ned032002 is offline
Re: Coolant
Sounds like the same thing that my Dodge Spirit did but my heater core was clogged. When the coolant got hot the coolant would flow out of the radiator and into the resevoir, then when that would over flow it would pour right onto the alternator.
