Old 08-06-2002, 09:53 PM
tunky tunky is offline
Unhappy temperature needle going sky high... help!
What's up everybody
I need your help. My temperature needle rises all the way to the max point and this only happens like in the middle of the day when is very hot outside. As soon as I start the car at noon the needle rises up and I drive like maybe five minutes or less and it goes to regular position again.
Please let me know what you all think might be the problem. Thanks
Old 08-06-2002, 10:00 PM
travis_118 travis_118 is offline
Send a message via AIM to travis_118
make sure you radiator is full of antifreeze....and your hoses arent leaking.
1997 Toyota 4Runner Limited
Built ZC in 90 Civic std model....
as marked001 says Don't click here
Old 08-06-2002, 10:28 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Also, check to make sure your cooling fan is working. It sounds as though when your car is stationary, it overheats, but when it is in motion (with air being forced through the radiator) it is okay... The fan is used when the car is at a stand-still and low speeds, but turns off when the car is going fast enough to provide it's own air-flow...
Air-conditioning could also cause this problem, if you're running it while the car is stationary, it will draw all the cool air out of the engine bay, causing the engine to heat up... Happens to me in my Jeep Cherokee alot, so I have to turn off the AC when I'm not moving.
Old 08-06-2002, 10:37 PM
GTA's Avatar
GTA GTA is offline
Whee..
Have you changed anything with the cooling system recently? When i changed my thermostat and radiator, i forgot to bleed the cooling system. This caused my needle to go up when my car was stationary.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 08-07-2002, 12:42 AM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
drain your radiator then fill it back up with new colant (if you havent already) then bleed it, thats what helped me, i also didnt have much of a gasket left between the upper radiator hose connection and the engine the gasket between the 2 it was basically gone, check that they are like 97 cents or sumthin like that, just check everything, good luck
2002 Acura TL Type S
1991 Honda Crx Si
